yup its true ... i picked a fight with a tidy looking supra TT dun know what mods it had but heard the blow off valves and huge exhaust ..
only just picked my Stagea up a few weeks ago n no offence but my last few cars have been quick (300zx TT, 180sx n a sylvia all with reasonable mods) i love my Stagea but its fully stock so bit slow ... but this guy was a full on tool soooo i couldnt resist.
I knew he was gonna kill me but honestly full credit to the Volvo look-a-like it wasnt as bad as i thought.. he clearly was pullin away from me but from the smoke comin out of that zorst he was hurtin it an it wasnt like he was fully leavin me, he prob pulled a car if that upto 100ks ... then very little upto bout 140.
Yes i lost and in any of my other carz i wouldnt be smilin but hahhaa i love it hez prob think WTF?? n i m thinkin damn with some modz this could be the ultimate sleeper :D
hahaha here comez my new addiction ..turbo back zorst, FMIC, filter, EBC, injectorz, upgrade turbo etc ..
https://www.sau.com.au/forums/topic/98875-stagea-vs-supra-tt/
sleepers are fun :D i cained a few vs v8 commodores with the 25/auto and its funny as watchin their reaction when u gun it and keep goin lol, they sorta laugh when u rev it at the lights, as if they think "are u serious" :lol:
bets race in the short time ive drivin it was with the 26 against a rb25 cefiro and i absolutely cained him everytime he tried to gun it off, lol, he sure looked abit suprised
Edited by StageZilla
Was Cruising with 2 of my managers yesterday, one has a 98' WRX, and the other, a 1989 R32 4 Door skyline with FMIC, Exhaust, Pod, and 10 PSI. We had a few runs, first few I didnt stall up, so they beat me quite easily :) But when I did stall it up, I found I could beat the R32 but still be around 2 car lenghts behind the WRX. Not a bad effort I didnt think! On Tuesday, I'm upping the boost to 10 psi in all gears and installing the GTT Intercooler...Would be interesting to see how I fair after those
  • 4 weeks later...
I really have to stop steering my way over here to the Stagea forums. Every single time without fail, I convince myself I HAVE to trade in my R32 GTS-T for a Stagea. The problem is, I am saving for a deposit on a house. Then I get in a huge fit over do I want a house sooner or a house later + Stagea.
Bring on your upgrades though - imagine the look on his face when he is smoked by a station wagon. Make sure to have a child booster seat in the back. And wear a hat. And a cardigan. Then laugh :lol: Let the kills roll in! :D
Edited by Big Rizza
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
