  • 8 months later...
I had hicas but put in a S13 non hicas rack. The factory powersteering lines wont mate up so i ripped them all out and got custom ones made. Because I had a hicas pump i took the back off it an ripped out the vanes so the bitch wouldnt pump out the rear stage. I bunged it up too :)
JK
https://www.sau.com.au/forums/topic/98896-power-steering/#findComment-2458922
Hella Flush so your sayying that a s14 steering rack goes straight into a cefiro with out any mods :S I find this a little different as i didnt think that s13 an s14 steering racks where the same. Not that im a silvia person unless it has 4doors and drifts it aint worth having. Cant wait for next yrs super drift rds im guna burn the candle for the cefiro crew
https://www.sau.com.au/forums/topic/98896-power-steering/#findComment-2500183
as we are on the topic of power steering, i just wanted to know if the powersteering pump from the ca18det engine/s13 would work on the rb20e engine/a31, it looks the same but i just wanted to confirm this, could anyone help
thanks
https://www.sau.com.au/forums/topic/98896-power-steering/#findComment-2507476
wait... on my 32 the front rack is completely seperate to the hicas rack, there is no plumbing between them.
on my friends CA silvia there is a connection that is bolted to the rack, but no fluid is mixed here.
i found this out when i locked the hicas on both cars so both definitely had hicas.
hicas cars have a pump that has 2 outlets and then the resevoir has 2 inlets, so the front rack and the hicas rack are completely seperate all the time.
i dont understand how a non hicas rack can be different then, cos i've definitely never seen any connections on the rack for hicas. rack has 2 connection, 1 in, 1 out
https://www.sau.com.au/forums/topic/98896-power-steering/#findComment-2510229
are you talking about the connections near the uni joint? where the steering shaft goes in? cos this isnt actually hydraulically connected, its just bolted on there.
just checking, ive never done it on a31 but i assume its the same as s13 as the solenoid setup looks the same from the top
https://www.sau.com.au/forums/topic/98896-power-steering/#findComment-2518998
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
