1989 Nov R32GTR 128,000kms displayed in Immaculate Condition (Few Pin Dents)
Recently Rebuilt engine/diff
N1 Turbos
Strengthened gearbox
New Alternator
New Fuel Pump
Xenon Bulbs
Nizmo headlights
Rear Locker/lower gear ratios
H/D Clutch
Nizmo Rear Lip
Nizmo Side Skirts
Nizmo Rear Pods
Blitz Exhaust
Sard Racing Radiator With Silicone Hosing
Apexi Air Filters
Apexi AVC-R
GREX Oil Filter Re-Location kit and Remote Oil Cooler(Mounted for maxium airflow)
Bilstein Suspension Coilovers
Cross Drilled Front Rotors/DBA slotted rear rotors
Endless Blue Race Pads
Limited edition Apexi Avcr
Nizmo strut brace
Nardi steering wheel (signed by Mr Nardi)
HKS Turbo Timer
Recently Resprayed although there are some pin dents and scratches
Aftermarket BOV's
Jap Headunit
Aftermarket FIMC piping
Earth wireing kit (7kw power gain apparently)
17x9 Yokohoma Model 6 Wheels with 20mm spacers
Just had a full service
$22,000 QLD Gold Coast
Kris-0401667877 (call if interested thanks)
PICTURES CLICK HERE
https://www.sau.com.au/forums/topic/98973-for-sale-r32-gtr-modded/
  • 3 weeks later...
PRICE DROP! Must Sell
1989 Nov R32GTR 128,000kms displayed in Immaculate Condition (Few Pin Dents + Boot Holes)
Rebuilt engine/diff
N1 Turbos (no shaft play)
Aftermarket Gearbox
New Alternator
New Fuel Pump
Xenon Bulbs
Nizmo headlights
H/D Clutch
N1 Body Kit
Blitz Exhaust
Sard Alloy Racing Radiator With Silicone Hosing
Apexi Air Filters
Apexi AVC-R Limited Edition
Bilstein Lowered Coilover Suspension
Nizmo Front Strut Brace
HKS Turbo Timer
Aftermarket BOV's
Jap Headunit
20mm spacers
Just Had a Full Service
Needs New power window motor (passanger side)
I have had this car for 6 months now and have never had any problems with it
Item Condition: Immaculate
Price and Payment Conditions: $23000 ONO NOW $20,000 Firm!
Email me if interested : [email protected]
Contact Details:0755788143 or 0401667877
Edited by l005e
DAMN
I thought this was sold already?
This is the one with a front LSD and Straight Cut Box huh?
How could your of not sold this yet?
If i had the cash i would ask if u wanted to trade plus cash!
How much power is it making?
Good luck with the sale dude!
  • 5 weeks later...
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
