Item: 2x hybrid t34r to04e turbos
Item Condition: brand new, never used
Reason for Selling: dont need them anymore
Price and Payment Conditions: $800 prefer pickup
I've got two of these turbo's that i want to get rid of. They are both brand new in the box never been used. they are ball bearing turbo's.
They are both hybrid t34r's t04e.
A/R is .50
T3 flange.
Good for 550 hp.
i want $800 each
pm me if your interested.post-21965-1135773532.jpgpost-21965-1135773565.jpg[attachment
16350:attachment]
https://www.sau.com.au/forums/topic/99957-fs-2x-hybrid-t34r-t04e/
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
