hey ..well today ive "installed" a GFB manual boost controller and a boost guage ..
prob is weather the boost is turned all the way down or up shows no difference on the guage.
the max it shows on the guage is 0.4bar (5.6psi if my maths is right) pretty shitty!!
Boost control install..
1)i unplugged the 2 pipes from the standard solenoid
2)removed the T piece
3)replaced the pipe from the intercooler with the pipe that comes with the boost
controller (in case of standard restictor in the pipe)
4)basically put the boost controller in place of the T piece with the arrow facing towards the turbo
5)put a large screw in the end of the other pipe that originally went to the standard boost solenoid.
is this right?
Boost Guage install
1) found the nipple at the back of the intake plenum
2) the clear pipe didnt fit (to small) so i cut the end of the black rubber cover and used that join the nipple and clear pipe (slid the clear pipe in and butted the nipple and pipe together)
4) fed through the firewall and tested
Is it possible that due to my connection it may leak pressure at anything above 0.4bar and therefor not read anything higher?
There doesnt appear to be any improvement in performance tho so im thinking its prob more the boost controller
any advice would be appreciated thanx
Lee
https://www.sau.com.au/forums/topic/99960-boost-guage-andor-boost-control-prob/
is this right?
Boost Guage install
Lee
Hi Lee, check the conection to the wastegate actuator. As per your other post, it looks to me like you have different connection to the wastegate actuator. The circuit should be like this;
I'C pipe------->Bleed valve-------->Wastegate actuator
:huh: cheers :(
Hey SK, cheers for the quick response
yeah its intercooler ----> bleed valve------> wastegate actuatator...
*scratches head*
no factory restrictors in place and the arrow is pointing towards the turbo :huh:
could it be the wastegate stuck or something along those lines?
Lee
*scratches head*
no factory restrictors in place and the arrow is pointing towards the turbo  :(
Lee
Hi Lee, stuck open wastegate actuator......hmmm......unlikely. Easy to check, give it a push with your finger. Or grab the vacuum pipe to the wastegate actuator and give it a blow, you can see the wastegate actuator lever move.
You should also check the bleed valve the same way (give it the blow through test). Make sure it is bypasing some airflow as you adjust it.
:) cheers :)
I am not sure what a GFB unit looks like, but on my 'Powerup MBC' I followed the instructions and had the same problem of not getting more then the standard boost. After stuffing around for a while connecting different hoses, I eventually took the MBC off and blew through the nipples while opening and shutting the valve, only to find that it worked the opposite way to the instructions. So if you blow thru the right connector you will feel a variation as you open and shut the valve and if you blow thru the wrong end it will have the same level of restriction no matter what position the valve is in.
My motor is a NEO and it has a three way T piece (with no built in restrictions): 1 - pressure in. 2- exit to the wastegate and 3 - exit to the solenoid. This 3rd hose going into the solenoid then has another hose going to the air intake pipe - this seems to me to be how the system controls the amount of pressure the wastegate sees by bleeding it off thru the solenoid. So all I did was pull the two pipes off the solenoid and attach them to the MBC (only opposite to the factory instructions) as per my blow test and whammo - variable boost.
cheers guys!! definatley worth a shot, i'll try that tonight if thats the prob could be a really good point for others to be aware of.
The pipe that normally goes to the standard boost solenoid (not the one from the T-piece) is the pipe that we put a screw into isnt it?? just checking but im sure the pipes are right
hahaa i just gotta laugh now, cos of the boost guage im now installing a single din head unit to make room for the guage underneath .. the aerial on the factory deck is nothing like a normal aerial, no matter what i try i cant get my circuit tester to light up to show me the positive and ignition hahaha.
excellent tutorial by alexcim on how to remove the head unit
Cheers guyz
Lee
    • Mixing things up - installed some leather recaros to match the leather seat covered rear seats. Interior looks pretty schmick now except for some slight wear on the steering wheel which I will monitor and address if it becomes worse or actually noticeable!
    • Didnt realise RB's had more then 1 head.
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
