  • Replies 67
Posted Images
Yer I've seen a couple of evo's do the Go-To-Whoa, normally kick ass.
Best was when they have to do the garage race, where the driver has to drive forward into a "garage" then reverse into the next one and repeat. A guy entered a moke into it and wooped everyone... :nyaanyaa:
The feel for imports entred has changed a lot in last few years, I normaly go for only 1 day (get board of it now) if its your first time going it should be a great day/night/weekend (accomodation will be booked out) but at night dont wonder by your self, also it has become much more then an Ausssi bogan event, more sorry to say Leb feast.
Also watch out for the mass of tity being flashed by random chicks.
Edited by race_snooze
I will be out and about from tonight onwards. I'm from canberra myself, and i think the local SAU crew here are meeting up for a cruise on friday night into braddon. IM not 100% sure if the parking is free though? I thought it was usually $5 odd.
Anyway where are you all meeting up friday night? Will come past and check it out. Will be good to meet interstate SAU'ers.
Dayne
Alright guys, Just to inform you all. This was taken off another forum (syndicatemotorsports.org)
"I saw in the paper that they were pretty much pulling over every car coming in from sydney way doing breath testing/vehicle inspections"
So apparently if your on the way down from Sydney, I'd be pretty careful. Wouldnt worry to much anyway - theyre not really targetting many of the lines, theyre more interested in the booner v8's. I went out into braddon last night, and the cops were so out numbered they gave up in defecting in the end.
Dayne
Hey guys just spoke to my brother whom is down there, they went down yesturday and there were cops going over eveything with a fine tooth comb so im going the hire car route.
Also for anyone that is interested check out the blue ford mercury that belongs to Bruno and painted by Impact P&P. Impacts my brothers shop and he painted the car. Sumernats is the first place the public will see it even thou its still not completely finished. The work on this car is awesome :P
Anyone that wants to meet up can also PM me for my mobile.
All we need now is someone to report back if the cops are defecting at the entry to Canberra on the Hume Hwy like they were 2yrs ago.
mY MATE Just rang me from the nats...
Coppers are again pulling all cars headed from Sydney/Wollongong to the ACT in a big way!!
Sniffer dogs as well, so be ware! There main pull over sport is Marulan!
My mates spoken to the coppers as he got noise defect already & said the cops are doing as many cars as possible this yr!
I came down tonight (well im at Goulburn so far) and I seen 6 cop cars in total (around Marulan) and a green pulsar with rims in the RTA station getting inspected.
Nothing outrageous yet, but then again I haven't crossed into the ACT border..
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
    • what sort of caliper are they? If they are a slider and you gave everything a good clean, you might need to regrease the pins. My guess though is they will come good after some abuse as suggested above
