i plan on putting in a roll cage in my car, but i have 2 concerns regarding it
1) is there some way i can still retain use of my backseat? or is this a sacrifice i have to make do without for a cage
2) is there any way it can be fitted in the rear without being put through my parcel tray into the boot ( stereo issues)
if not then ah well ill make do without the cage but just an idea incase the car starts runnin quick times
cheers...ben.
https://www.sau.com.au/forums/topic/100172-rollcage/
1) Generally Japanese cages don’t go through the parcel self. They bolt onto the rear wheel arches, as per the pic of my cage.
2) As you can see from the pic the rear bars bolt onto the wheel arch, thus having a rear seat wouldn’t fit unless the seat was re made to fit around the bars, and then you have the issues of getting around the diagonal brace if you wanted one. Why you would I’m not sure as its illegal to carry people in the back with a cage.
Hope that helps :D
*Edit* If your running quick times you’ll need an ANDRA approved cage anyway, so I guess the above is really not relevant as you would be getting a custom one made no doubt.
Edited by Nismo_Boy
https://www.sau.com.au/forums/topic/100172-rollcage/#findComment-1826442
  • 10 months later...
yeh doesnt matter its too hard to do and still keep my interior as is...yeh i dont put people in my backseat anyways so it doesnt bother me bout that...i was gonna put a 1/2 cage in and register it as a 2 seater thats legal but again stuffs the interior...i'll just strip it out later on next year and get my uncle to weld me up a cage, run a few fast times then go back to my interior...
ben...
https://www.sau.com.au/forums/topic/100172-rollcage/#findComment-2647406
if you want to run unrestricted ETs with no cage, take a drive down to Heathcote.
ben...
https://www.sau.com.au/forums/topic/100172-rollcage/#findComment-2647900
    • This is aem disk setting in aem tuner and still 180 dgree off or ignition on exhaust cycle is it from cas it self as cas seems wouldn’t fit in cam shaft if wrong position and wiring been verified any ideas
    • Oh yeah that would work excellent. Should be the same diff housing & everything. Shoot me a text or call me 260-750-2246 -Cody
    • Oh right, I didn't realise it was your car. Please do! Makes me feel better about mine. I also have a big scrape on the front left bumper where someone presumably used the wall to guide the car into a parking spot  But somehow all the funds go towards mechanical things and the cosmetics stay forever unfinished... Interesting, I don't think I have seen it before. But after seeing @PranK's rusty roofline on the BMW I'd probably leave it alone. Wouldn't want water to get in there.
    • Thanks mate, thought you might know the answer.
    • Infiniti US are teasing a manual Q50 as a way to refresh a (very old) model. https://torquecafe.com/manual-performance-sedans-arent-dead-yet/ Can't be too technically difficult given the Z has the same motor with a manual gearbox......here's hoping there is a JDM version we can import here, that would save me a world of headaches
