The new GT30R is being presented to me on the 4/1/06 which is an internally gated T3 flanged turbo with the 0.63 A/R housing. The compressor still flows around 50lbs/min so will be good for power figures near 500hp and still maintain early boost. These will bolt straight on to your existing stock housing with the only change needed being braided oil and water lines. Even with the cost to adapt it, it should still be around the same price as the highflows but with more effieciency so less boost will be required to achieve the same result. PM me if you are interested.
https://www.sau.com.au/forums/topic/100500-new-gt30r-in-town/
Ok, sorry to get everyone's hopes up but here is the bad news:
The turbo is basically a GT30R with a hole cut in it above the turbine for the wastegate. Then they have bolted this housing thing over the top which has the flapper built into it. They have it all closed off except the turbine hole 2.5 inch which is where the wastegate gases have to exit also. This means that the dump pipe is no longer T3 but a three bolt triangular config and also means that your standard dump will not bolt up to it.
I expressed my disappointment to him about Garrett failing to come up with a decent idea. I showed him how it should have been made and we both can't understand why Garrett chose to do it the way they did.
He is going to get back to me on some grafting options where your existing exhaust housing may be able to be adapted to a GT30R front. This, I am hopeful, will achieve the task.
Other than that....if you don't mind paying $2000 plus an extra $600 in adapting costs, let me know....lol.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
