haha...you have no business in any of the shit i give ula. me and him do it for a laugh (ie i was replying to him until you jumped in - but its been fun having a go at you. coz thats all your good for, really.
btw: look at the quote below your avatar
just managed to quote it again, didn't you?
https://www.sau.com.au/forums/topic/10068-power-chip/page/3/#findComment-163353
  • Replies 56
<<< hands legal documents to poyz obtained from high court to bring him back to reality saying that his pulsar is and wont be the fastest car ever in the world, and to remind him that if they r the greatest thing ever made there would be a pulsar forum where he would mumble on about how good it is>>>
:P
https://www.sau.com.au/forums/topic/10068-power-chip/page/3/#findComment-163365
hmm..... a bit off topic methinks.....
inasnt... i dont know why you keep jumping in but what me and poyz talk about is between us... meaning no one else understands... which is also means anyone that butts in doesn't have a clue what we are on about.... you understand it yet? :D
https://www.sau.com.au/forums/topic/10068-power-chip/page/3/#findComment-163871
It's quite obvious that a standard GTi-R is quicker than a standard GTS-t. I don't need to re-enforce that.
And about this mods thing. That's the entire point. Everyone here bought their cars to make it quicker (well maybe a large proportion - not everyone can afford more mods) And all you seem to do is paint your interior blue.
Btw: I don't know about you, but I consider it significant that a GTi-R can out quick a GTR. Considering it's a smaller/less powerful car from factory. Kinda like a Datto 1600 running low 12's all days. That's a freaking acheivment. Does that mean this Datto can't go on about beating a stock GTR?
P.S I might see you at that dyno day. I'll have a chuckle at your interior then since I'll see in in person. :lol:
Originally posted by INASNT
https://www.sau.com.au/forums/topic/10068-power-chip/page/3/#findComment-164357
Attached below is the dyno graph for a rb20det fitted with the TSI engine management system. The car had 440cc GTR Injectors and an rb25det afm which was quite a combination to overcome with the standard ecu. As you can see, the TSI did a good job in handling fuel and ignition duties at the 19psi required to make the power on the graph. The tune was very conservative as with all our street tunes and there was more power to be had if we pushed the timing.
https://www.sau.com.au/forums/topic/10068-power-chip/page/3/#findComment-172686
The shootout mode is there for the sake of obtaining consistent results in different atmospheric conditions and for cars of different drivetrains. If the correct inertial settings for each car are entered then the power reading will not be inflated.
https://www.sau.com.au/forums/topic/10068-power-chip/page/3/#findComment-178544
so shootout mode aint 100% accurate then.
https://www.sau.com.au/forums/topic/10068-power-chip/page/3/#findComment-179012
question if a get a power chip, what exact features does it optimize
i cant tell you what it does on an rb25 unless someone loans me the ecu for a day....
but i have compared an image on the rb30 and all it changed was advancing certain spots on the ignition advance map and changes to two constants (rev limiting i think - since they advertised that rev limiting was increased on the vl/r31)
there were no changes to the fuel maps or anything else. from what I understand the AFC will alter the signals to the ECU with determing the Voltage Quanitifier map from the AFM. i dont know what else it does without looking into it further
https://www.sau.com.au/forums/topic/10068-power-chip/page/3/#findComment-180557
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
