  • Replies 426
Posted Images
Dont give false directions :D
If anything dont give them any information, but false information will only look bad on the club and hinder our future cruises. If you are expecting trouble from the police because of your driving or poor quality mods, dont come on the cruise.
Dont give false directions :)
i do agree with you even though on 2 occasions ive said tell them barrossa
i also was thinking for dinner when where down there is to find a local pizzaria and get a few party pizzas or sumthing like that we could even book ahead and give them numbers of the definates of who are comming and get a deal or sumthing
bit off topic but paul walker's gay.
bite your tongue
:lol:  :lol:  :lol:
hey pokie im sure if you posted your pic you would get a ride...........
i mean in a skyline  :O
i'm not posting my pic up EVER
hmm also i'm startin to get confused, is the
cruise heading up north or down south?? :)
Edited by pokie
"If you are expecting trouble from the police because of your driving or poor quality mods, dont come on the cruise. "
Yeah man i agree with you 100%, i say ban all modded cars that can be defected from the cruise!!!!
Hmmmm i wonder how many people will attend in their STOCK skyline!!!
There is when there's stupid talk about illegal activities.
We need to keep it clean in a cruise thread when I KNOW there are members of this board who are SA Police.
There's no need for nit-picking, it only provokes arguments.
We all know what 4doorsleeper is getting at.
cubes, why are you always editing my posts?
I've only edited one of yours; two of Chris's.
Posts don't dissapear, I haven't deleted any of yours, only edited 1. :(
I've deleted a thread where some one (I can't remember who) felt like having a pissing competition by comparing how quick they can get to Victor or something... Thats just plain stupid.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
