  • Replies 71
If we need a minimum of 6 cars, and this is a "bling" event, id suggest that we first use the sort of skylines that Autosalon aims at ("blinging")
Ill have a new interior by then also, its white suede with grey leather
Cant be hard to get 6 good looking skylines
Would also be good to get a variety, R32 R33 R34 gtst's and gtrs
Either way, im in
Either way, im in
Not a bad idea....
but poor Mr Stagea :O
Hey Jago. just a quick question. How long is that inlet system you have?is that custom?
everything is custom mate, no kits for the 31, for anything really (or are hard to come by and expensive)
As for autosalon, i wouldn't mind goin, just gotta fix up some paint tho, it aint 100% show grade but hey, it's different
Where have you been @ phil.
Whats going on with the car.
yea i just been here and there mate, haven't seen you around much either :(
As for the car, just came out of the workshop, fixing a heater hose, which caused major overheating. High pressure hose power steering leak, screwed sump plug, fitted bigger injectors, upped the boost and dyno tuned the microtech. Ran 182rwkw on the autosport engineering dyno @ 13psi, peak power at 7000rpm ;)
What bout u man? or u keep her the same? nice lookin 33 i must say
Man this seems to be getting serious... Definitely count ME in!!!!!!!
After all.. I'm probably teh biggest RICER in here...
BLING.. check
PAINTWORK.. check
LED underbody and interior.. check
AND
NO IMPULS.
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
