  • Replies 71
If we need a minimum of 6 cars, and this is a "bling" event, id suggest that we first use the sort of skylines that Autosalon aims at ("blinging")
Ill have a new interior by then also, its white suede with grey leather
Cant be hard to get 6 good looking skylines
Would also be good to get a variety, R32 R33 R34 gtst's and gtrs
Either way, im in
Either way, im in
Not a bad idea....
but poor Mr Stagea :O
Hey Jago. just a quick question. How long is that inlet system you have?is that custom?
everything is custom mate, no kits for the 31, for anything really (or are hard to come by and expensive)
As for autosalon, i wouldn't mind goin, just gotta fix up some paint tho, it aint 100% show grade but hey, it's different
Where have you been @ phil.
Whats going on with the car.
yea i just been here and there mate, haven't seen you around much either :(
As for the car, just came out of the workshop, fixing a heater hose, which caused major overheating. High pressure hose power steering leak, screwed sump plug, fitted bigger injectors, upped the boost and dyno tuned the microtech. Ran 182rwkw on the autosport engineering dyno @ 13psi, peak power at 7000rpm ;)
What bout u man? or u keep her the same? nice lookin 33 i must say
Man this seems to be getting serious... Definitely count ME in!!!!!!!
After all.. I'm probably teh biggest RICER in here...
BLING.. check
PAINTWORK.. check
LED underbody and interior.. check
AND
NO IMPULS.
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
