Hello all,
Well the time has finally come. I have put a lot of time and effort into this project but I have found that upon completing it I hardly ever use it on the track due to other commitments. I'd really like to see the car sold whole as it really is an awesome package but I have also offered the option to buy the engine / etc with a swap for standard engine.
The engine and all tuning was done by Ben at Racepace... it pulled 324rwkw on the Racepace dyno with pump fuel and has a massive power band making it very driveable.
The car itself is very tidy, no dents, no scratches, interior perfect, no previous damage.
More info available if you want it...
Car - 94770km
Engine - 7000km
Power - 324rwkw Racepace dyno (since ran 350rwkw at Racepace on 100ron)
1/4 mile - 12.2 with 2.049 60' and 122.03MPH
Engine
- RB25/30 3.0 litre
- HKS Stopper head gasket
- JE Custom Forged Pistons
- Carillo H-Beam Rods
- Nismo Bearings
- N1 Oil and Water Pumps
- VCT is plumbed and works
- Tomei Poncam's
- Greddy Oil Cooler
Turbo and Exhaust
- Garret GT35R with 0.82 A/R turbine hsg
- GCG XTR Turbo cover
- GCG 6 into 1 manifold
- PSR 45mm wastegate
- 3.5in into twin 2.5in exhaust
- Blitz Type-S EBC
- AVO Intercooler 600x300x90 Bar and plate
Fuel and ECU
- Bosch 044 Fuel Pump
- 215 lph lift pump
- 1 litre Surge tank
- SARD Fuel Pressure Reg
- RX7 550cc Injectors flow tested and cleaned
- Apexi PowerFC with handcontroller
- Z32 Air flow meter
Brakes and Suspension
- KONI Adjustable Shocks
- Full whiteline handling kit with sway bars, springs, bushes etc.
- DBA 4000 Slotted Rotors
- Ferodo DS3000 Pads
- 17 inch rims with Falken Azenis-Rs
Other
- Custom RacePace catch can with oil plumbed back into engine
- Unifilter pod
- Daikin Heavy Duty Clutch
post-817-1136779906.jpgpost-817-1136779992.jpgpost-817-1136780042.jpgpost-817-1136780281.jpgpost-817-1136780360.jpgpost-11016-1124415448.jpgpost-817-1136781068.jpg
Keen to move this car, so I'm now asking only 20k wtf! Would also consider trades for S15, R34 or MY99+ WRX with cash adjustments for whichever car.
Karlos
Edited by raist60
  • 5 months later...
  • 2 months later...
Karlos, clean car... seen it many times down @ Racepace/Sandown :laugh:
I think you'll have to separate, its the only way you'll get a decent sale.
I sold my motor off, Matt did the same for his, and i know of another guy doing the same interstate.
Built motors sell much better without the cars for some reason.
Dont ask me why, but i got my asking price as has everyone else.
All the others who want the "whole car" end up just wasting your time
cheers - ash
Thanks for the advice mate I'll give it a go :)
K
Karlos, clean car... seen it many times down @ Racepace/Sandown :P
cheers - ash
It goes really really fast... :D
I think Im the other guy who Nismoid's talking about.... I got more for my car in parts than people wanted to pay for it 'whole'.. Unless you have a dire need to sell it, hold on to it for a while... the whole modified car market is pretty slow these days... especially for skylines/GTRs :mellow:
I think Im the other guy who Nismoid's talking about.... I got more for my car in parts than people wanted to pay for it 'whole'.. Unless you have a dire need to sell it, hold on to it for a while... the whole modified car market is pretty slow these days... especially for skylines/GTRs :happy:
Dang. **shakes fist at fuel prices** :blush:
  • 9 months later...
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
