Item:GTEC PRO
Item Condition:BRAND NEW
Reason for Selling: NO USE ANY LONGER
Price and Payment Conditions:$180 (once payment received will post for free interstate if need be.
Extra Info:Itek Has Only Been Opened but Never Used. Item Inside Still In Plastic. GTEC PRO IS WORTH AROUND $400. YOU CAN DO QUARTER MILE, Mph, BRAKE DISTANCE. All you do is plug it into your cigarett lighter and put it on your dash and off you go (no wiring needed at all), they say they are like 99.999% accurate.
Contact Details:SMS me on 0434 116 042
https://www.sau.com.au/forums/topic/101459-for-sale-gtec-pro/
yeah im pritty sure it can do all this stuff, it is still in the original box with instructions and everything, but like i said i havent even used it and im not very computer literate and dont have a camera to throw photo's up on the net.
Let me know if interested
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
