Which would you rather?
13 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Im trying to organise a fishing trip so just let me know if you want it chartered or if you want to hire out a boat.
Right now i just want to see how many people who are interested so i can get prices as we may need more than 1 boat.
Things you'll need:
-Fishing rod + bait
-Sun Screen
-Hat
-Food (not sure if we can bbq on the boat)
I want to organise it for a saturday or sunday at the start or middle of march.
i've got a file showing the size and bag limits of nsw fish so when i find out how to post that, i will.
KEEP YOUR EYES ON THIS POST, ILL BE UPDATING IT REGULARLY.
https://www.sau.com.au/forums/topic/101833-sau-nsw-fishing-trip-deep-sea/
I hope you have your fishing license if you thinking of hiring a boat ( big fines if you get cought without ) .
Depending on when it will be i'll be in too and if there is not to many i can supply the boat as well. A 24' with twin outboards all you guys have to do is pay for the fuel and clean the boat when we come back .
thanks for the offer mate, how many people can it hold?
I will be in for sure.
If we go deep sea, for those who have not been before, it cn be a killer.
The first time i went 5 mins after stopping i was sick as and laid down on the boat until the got back to shore.
The second time i was sick again but it made great berly as i kept fishing.
ok.. keep it coming guys. i need numbers before i book anything, looks like we're going chartered..
so far its:
SECUR1TY
N1GTR (maybe)
wrxhoon
NXTIME (+1)
d00dz
GTR_Legend
Tommyk
OSH33N
just add your name to the list and how many people you want to bring if any.
everyones welcome, i just need a definate number to check out costs.
  • 1 month later...
almost forgot about this..
ive got uni coming up and my rebuild has been keeping me pretty broke most weeks, but i still want to organise something soon. maybe a drive up to terrigal or something in the meantime, because ill be needing to run my car in anyway.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
