Hey Guys,
While driving my r33 gtst today i heard a noise under the car pulled over and there was a sensor that had fallen from somewhere scraping under the car. So i got the car home straight away and put it up on the ramps assuming it was my o2 sensor however its after the cat in the middle of the car on the passengers side and the wire runs up through a gromet to a fitting underneith the passenger seat. However after a closer look i realised that there is another sensor further up the exhaust which is obviously the o2 sensor. Does the r33 run a temperature sensor in the exhaust? I cant figure out where it has come from or what it is.
The sensor is damaged so i need to know where it is supposed to go and what it is so i can replace and fix the problem.
Thankyou for your help,
Regards
Dan
https://www.sau.com.au/forums/topic/102654-exhaust-sensor-fell-out-s/
From what you have described it is the exhaust temp sensor. I'm not familar with the temp senor arrangement in the R33s but the R32s have a sensor/switch which screws into the CAT. Unlike the R32s the R33s exh temp sensor is monitored by the ECU (signal wire is Pin 57 and earth for the sensor is Pin 30).
If you have an aftermarket CAT its possible no provision exists for the sensor in which case it was left loose after installation of the CAT.
Can you take a photo?
Hope this helps
Cheers
Edited by BH_SLO32
Its a CAT Temp sensor.
So.......
Dont worry about it. Its just used for a dash light, serves no other purpose.
Its perfectly safe to tuck it up under the body, or remove it all together if you wish, your choice. Wont hurt the car by not having it
I havent used my since day one of owning the car.
Not has anyone else thats changed thier CAT as far as i know as most non-factory CAT's dont have a hole in them anyhow
Hope this helps
Cheers
what do you need to do to stop the exhaust temp light from flashing on your dash all the time as i have a faulty sensor
O ok well that would be the case then you see i have a trust turbo back exhaust so its all aftermarket. The cat included there is no provision for it. It must have been sitting on that cat itself which was providing enough heat for the warning light to be off for the majority of time while driving. I was concerned that the heat sensor would impact the engine by if the sensor was saying that the exhaust gases were to hot that it would run more fuel to cool down the temps. Are you certain that this isnt a case and it serves little more then a potential light show on my dash?
As i said, im am 100% certain. I havent run it on my car ever. Its just tucked in there.
Its only an "over temp" warning for the CAT. Ie its getting to hot, which for anything other than a stock car... is probably gonna happen.
Just tuck it back under there :)
hefer81 - If your light is faulty - you'll probably just need to rip out the globe :) Although i havent heard of one every playing up.
Or maybe see under the car where/what your sensor is upto.
I have taking my sensor out completely as the ligth was staying on as it was damanged from draggin on the road. This made the light on the dash turn off so im just going to leave it out and put the gromit back in. This wont be a problem will it?
No problem doing this. If by removing the sensor the light has turned off, the problem has been solved.
sweet thanks mate all finished ive plugged the hole back up lol i used a despent .22 long rifle shell to fill the hole in the grommit where the lead went through into the car to block it off so water doesnt get in there :(
I have had this exact same thing happen on my GTR it is good to hear that it is not causing any harm, my warning light also flashes constantly, i will have a set of nismo gauges soon so when that comes i guess i will just pull the globe. My exhaust is still stock does anyone have any suggestions on how to block the hole?
Sorry for the tread hijack
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
