Odometer
The Odometer on my car (R33) has stopped moving, the trip meter doesn't move either. Everything else works like Speedo so I'm a little confused...
I guess it’s been wound back and it hasn't been working now for about 8 months. I've had the instruments out and they look 100% fine. I just didn't have the guts to start removing the dials out of the instrument panel to look inside them for damage…
Does anyone have any suggestions?
https://www.sau.com.au/forums/topic/10266-odometer/
Originally posted by ndr
I have a standard speedo in great working order if you need it.
Neil.
My R33 is a series 1, would this speedo work in it? and if so how much?
Also if I do remove my existing speedo section out of the instrument cluster to have a futher look do you need to take the needle out? and if the needle is taken out will this effect the calibration?
Thanks guys.
https://www.sau.com.au/forums/topic/10266-odometer/#findComment-165678
mines the same guys i have posted a thread in WA asking how i get the bloody thing to work as well! Same deal trip and odo stopped everything else working A1. Mine has also been tampered with on australian soil too so it seems (and i bought it privately and he seems to have tampered with it in the last 6 months of him having it) all it seems be able to do is rip the instrument panel out and have a look yourself or have someone look at it for you. Pain in the butt i know mine has stopped for two months now and be probably another two months befor ei get it seen too.
https://www.sau.com.au/forums/topic/10266-odometer/#findComment-167564
FlyGuy,,,,sorry I don't know if S1's and S2's are the same,,,,I think they are,,but don't hold me to it. Changing speedo's is piss easy,,,,remove the whole cluster,then un-clip the front screen ,then unscrew the speedo itself by the screws at the back,,,reverse all to re-install. No needle work is required. I'll sell you mine for $100,,,it's in ABSOLUTE PERFECT working order. Has 78655 kays on it....
Neil.
https://www.sau.com.au/forums/topic/10266-odometer/#findComment-168509
  • 3 weeks later...
Hi Guys,
I own a R33 gts25t and my odometer / tripometer have stopped also, and its giving me troubles since im trying to sell it at the moment as well..
A few people on here have mentioned fixing it themselves or taking the dash to an "instrument tech"
Can anyone who has had success fixing these, tell me who / where they took it to get it fixed (im located in brisbane, but if still supply name of business maybe i can find something up here that can do it also)
and/or more detail information about how you went about fixing it yourself.... any help would be greatly appreciated !!
https://www.sau.com.au/forums/topic/10266-odometer/#findComment-192456
As I just indicated in another thread, I take all the issues with my car to (including fixing the odometer)
Gavin Woods
Auto Tech
23 Gibbs Street
Labrador, QLD
Ph: (07) 5529 2313
I know I sound like a broken record mentioning this guy all the time. But he does good honest work that doesn't cost the earth.
Yes he is at Labrador, but it only takes 30 minutes to get there.
I've suggested many skyline owners take their cars to him and all have had nothing but praise for him.
Mario, Maybe you could get the throttle body and odometer looked at at the same time?
https://www.sau.com.au/forums/topic/10266-odometer/#findComment-192658
It didn't take long. But I normally take the whole day off work and go down and leave it with them the whole day.
But I'm sure if you ring him and work something out with him, he'd be able to give you a better idea.
I can't comment on the price because it depends on how much work is involved with doing your car.
https://www.sau.com.au/forums/topic/10266-odometer/#findComment-192782
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
    • Can you also make sure the invoices on the box (And none exist in the boxes) are below our import duty limits... I jest, there's nothing I need to actually purchase and order in. (Unless you can find me a rear diff carrier, brand new, for stupidly cheap, that is for a Toyota Landcruiser, HZJ105R GXL, 2000 year model...)
