  • Replies 717
Well I watched JAS-25T put Humbla up on the board with 205rwkw.
I didn't see much after that. Until..... I saw a blank spot.
Was this because ours was no longer deemed as stock ? Nobody has told us yet still...
(Assuming there was a protest or whatever) Who's call was it on stock or not ?
As I said earlier, my son was told by the dyno operator that all that was needed with perfect AFR's, was an aftermarket turbo (after having stuff like PFC, big injectors, split dump, E-Boost -2, splitfires, etc etc
Who is going to tell us what is going on ?
El bee
:P
I still dont believed i got 197kw@10 Psi,
just way too much.
I was expecting 170ish or 180ish kw MAX,
the figure wasnt right, unless i have an Aftermarket Turbo or ecu, which i am not aware of.
bonus? maybe?
i wan to get another dyno run, maybe at HITMAN,
to see how much the real figure is.
El Bee,
Jason did put Humbla up in R33 stock but then it was wiped off (not sure by who) after it was made known that it was a high flowed standard turbo (and hence deemed not stock). I took over the whiteboard duties after Jason left.
:P
just way too much.
bonus? maybe?
Looks like RBFIRE is out.
Anyone else for the "Turbo-off" ?
Looks like the Dyno was way out according to him.
I am inclined to agree to a point.
El Bee
yea, i believe its out by miles,
the only mods i have are:
- split dump
- 3.5 Cat back
- R34 Ic
- K&N
- 10psi boosted.
as far as i know ppl have similar mods,
they make about 170-180
even tho my engine low kms, but cant be that much diffrent.
Seems to me that you have a stock turbo if you say that you do.
If you tell the world that your turbo has been high flowed, then you have an aftermarket one.
El Bee
when i installing my split dump, the turbo seem original.
the bolts that was holding the dump pipe pretty much rusted, stucked hard.
snapped 1 of the bolt while taking it off.
SO i dun fink I have aftermarket turbo,
If the figure is rite,
my best bet is the ECU,
but when i bought my car,
it stock as a rock, as it seem so, and it fresh imported.
:P
just way too much.
bonus? maybe?
Hehe.. good thing my PFC isnt tuned at all... as I got 185kw from a horribly de-tuned 'standard' turbo (so I thought)... then to find out on saturday arvo that I actually have an Apexi 380hp turbo!
If I had have won, I would have looked like a real asshole if anyone noticed I have an aftermarket turbo... lol
and not sure how the dyno reading can be out when everyone else was getting less than expected figures or close to expected! maybe something happened later in the day?
not sure why everyone is getting worked up? it was a fun day!!! and i'm sure ben was feeling pressured to get all those cars off and on! its not like its a proper tune!! so why is everyone hassling?!
either way.. thanks to adam, charlie, jas25t and steve for the day :P was good fun!!!
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
