The exhaust (cannon) on my car is screwed, it has a bit of a smash on the bottom which I have been told would of broken the baffle or whatever is inside. It has a rattle to it when the car is running, and the tuner said that it would be robbing me of power the way it is.
I have been thinking of just cutting it off and welding a straight pipe where it was which I'm sure you have all seen on "drift" cars.
But I'm not sure of how loud it will make the car?? It isn't very quiet as it is, but I don't want it going any louder if possible.
The exhaust is 3" from the turbo back, and I can't remember if there is a Cat-converter etc. on there.
Any help would be much appreciated.
Cheers :(
Edited by CAT_SPEW
https://www.sau.com.au/forums/topic/103119-straight-exhaust-on-rb25/
You'll be heard 4-5 blocks away, and i seriously mean that.
It's gonna be loud loud loud :(
If you dont mind it... "it" being the horrid drone and noise if its a daily...
And you dont live in an area that you can get into trouble for having it like that... i guess there isnt much to stop you.
But yeah, gonna be louder dude when its on song and @ idle
R31Nismoid - Don't take this the wrong way, but have you heard a straight pipe on a RB25? Or are you just assuming it would be really loud? Just curious?
Can anyone recommend a decent exhaust to get? That isn't very pricey? Or are they all basically the same just with a different brand name?
well if mine didnt have a staight pipe (just one muffler, "race"-cat) and it was loud... under load (before i had an external gate)
its safe to assume with no muffer in the system, that logic would tell me its going to be louder than what i had, it might be the same, but i dont think so.
I kid you not that i could be heard easily a block away from my house... :D
There are a lot of jap brand exhausts @ cheap prices in the For Sale section (on this forum).
Also from importers that for your car would all be a bolt on affair.
For under $1000 that aint bad (in stainless)
Or, better yet, why dont you just get the muffler replaced? I reckon $200-$250 would cover you for a replacement at the worst cost.
Just get them to make a flange, will come in handy for those pesky EPA letters which everyone seems to get once or twice in thier life (if your vic that is)
We used to run 3inch pipe for our complete exhaust...thats right...no muffler at all......it was loud but not as bad as you think....it sounded like a rotor. Drove it around on the street...you would get the occaisional look but nothing major.
i have the buddy club spec 2 exhaust on my rb20 and while it sounds awesome it is very loud due to the fact that its nothing more than a straight pipe and a *tiny* resonator.
got a bit annoying as a dd, but it does have a silencer to quiet it down should you decide to retain you hearing.
R31Nismoid- What do mean by getting a flange welded on? Do you mean so I could just take the "cannon" off for track use then stick it back on when on the road?
Yep, thats what i mean :D
So you get the quiet (kinda) on the street and then loud when you want it.
Or then you can even get a really quiet muffler (not a tin-can-cannon thing) and have it really quiet and swappable.
Just some ideas
Your cannon muffler is on a flange, right? Unbolt it and see how loud it is. R31Nismoid has got to be on the money... my mate had an R32 GTS4 with an 80mm pipe, no cat and one rear cannon muffler. It sounded like a Mack truck and I could hear him coming down my street. (street is windy and about 300m long)
did you ever have it DB tested?
i clocked... 120 with a muffler  :D
silly R31house system that was the supposedly loudest one in thier shop going by thier website
I used to have no mufflers on my GTR; dual 3" (with cats) into 4".
That was 105dB at 3500RPM under no load (i.e. stationary test). It was
louder under load and at higher RPM, but I never measured it.
With a 4" resonator and a 4" muffler it's now 95dB @ 3500 (same test).
Regards,
Saliya
Unfortunatly it isn't on a flange atm, just welded straight on. One of my dads friends has a DB meter so when it comes time to decide I will chop it of, test it. And if it's too loud then I will just go with your idea Nismoid and weld a flange on :)
Just out of curiosity, what muffler do you have xr8eater?
i think the db limit is 100 in QLD not sure?
Holy sh|t! Thats tops :)
I thought the EPA was Australia wide (and only being commonly visited by Vic people hehehe)
Vic/EPA is 89dB, a stock Exhaust GTR/RB26 rarely passes anymore as the test is done @ 4800rpm. Used to be 4500rpm if i recall and they would "just" snip over the line.
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
