I just sold all four (front and back) for $300 and I was told I was, 'a bit farken rude to be asking that much'.
Now I know I'm mistaken. To everyone who wants to pay sh1t money for good stuff and is a d1ck about it, go and thumb-ya-bumb
Adrian
:P
Adrian
lol man i sold mine for a lame $200 :P farkkkkkkkkkk
Adrian
i knew it was a good buy so i had to buy them off ya :)
:angry:
Edited by KamikazeR33
