hi people,
im selling this ca on behalf of a realtive who is going to loose his license soon for 13 months so hes decided to sell it rather then let it sit in a garage for 13 months.
THe car was imported over a year ago under the 15 y/o rule and was engineered and registered in Victoria. The registration was paid on a few weeks ago also.
THe car came with a few dints here and there so the car was fully presrayed in black metallic with a very noticable gold pearl. THE rear spoiler was removed and the holes blocked off. Bodywise this car is immaculate except for the front bar which has a cracker on the lip which will be fixed upon sale. This car looks abosulutely stunning especially when the targas are removed, a great example of a cruising car
Engine wise this car has undergone the fulll treatment with genuine Nissan water pump and timing belt along with a full service not long ago. The car is is on 106,000 km and drives like a dream as auto NON TURBO are more reliable than the twin turbo version.
Interior wise the 2 standard ZX seats were removed and 2 Recaro lookalike bucket seats put it. The boot has been custom made and new compartments to match were also installed. THe car also has remote keyless entry
The car drives exceptionally well as it has been maitained very well. Mechanically the car is A1 and no crash history, with inspection welcome.
The car is up for sale for $10,500 and is in melbourne (broadmeadows)
All replies for pics or questions about the car can be done via pm or calling me on 0408 57 86 27
thanks
Edited by nuR.spec
https://www.sau.com.au/forums/topic/103347-fs-1989-nissan-300zx/
http://www.skylinesaustralia.com/forums/in...showtopic=69225
6. No posting on behalf of others! - If your mates want to advertise their car here on SAU, tell them to register.
If you post for someone else, there is absolutely NO ACCOUNTABILITY nor options for recourse if something were to go sour in the deal. If your friend wants to sell his/her car, get them to register. It takes all of 2 minutes.
If you dont own it, you can't sell it.
okay then u try an explain that to a 40 year old person who can hardly speak a word of english that they have to register on SAU when their brother who is a frequent user( thats me) cant sell it on his behalf. He lives under the bloody same roof what is your problem?
Guest
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
