[EDIT] Gearbox also needed now...
Hello Everyone,
Im looking for an RB25DET to replace my RB20DET in my R32. Im after the complete motor, turbo and loom. And everything else i need. I will be using my gearbox and clutch from this motor. If anyone can tell me what else i need, it would be appreciated. Thanks,
Troy
https://www.sau.com.au/forums/topic/103593-wanted-rb25det-and-gearbox/
  • 2 years later...
Hello Everyone,
Troy
i have a complete RB25 det neo for sale. it is a low km import never been used and will sell for $2300
if interested also i have a 5 speed manual turbo box also low km import
