hi guys, i'm researching a suspension setup for my r33 and i came across " KYB AGX Adjustable Suspension ".
i read a few reviews from seemingly happy wrx owners but thought i'd check with you blokes.
i found my info by searching on yahoo. could not find anything on skylinesaustralia search.
any thoughts?
thanks............
https://www.sau.com.au/forums/topic/103634-any1-heard-of-these/
Had some of these in my first 180 and was very impressed with them, particularly that when you adjusted the damper setting you could actually feel a big difference, unlike most systems I've tried.
I was really happy with them combined with 5zigen springs, great for the street. I'd get them again
cool, thanks phunky monkey.
i was starting to think that no one had heard of them.
i can get these at a good price so i think that i'll give them a go!
thanks for the reply
handyandy
For what it's worth, KYB actually make the Nismo shocks.
Gotta be happy with that.
cheers
Muz
muz....
no sh*t!  i wonder why so few people have heard of them?
Does this mean that they are an inferior product compared to say the more reputable ones like koni's, bilstiens ect???
what?
why would they be inferior if KYB make shocks for nismo, seeing nismo is big up in there on the performance upgrades. KYB is good, kyb make most suspension on standrd cars, along with alot of other parts.
I have kyb agx adjustables on my s15.... They are ok. I bought them because I wanted the adjustability...
Having been in a few cars with bilsteins and konis, they are much better.
Apparently the reason it feels better is because the valving is a lot mores sophisticated.
I think you will find most racecars have european shocks. Japan is good at making many things but shocks isn't there strongest one.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
