Hey all,
i've recently picked up my stagea and its so sweet, only thing it needs is some attention to the brakes. the front pads are low (not seriously low but will need replacing soon).
Well after a good blast up Mt Mee (for any of you here in brisbane) I noticed that stopping power wasn't as good as I'd like. i realise these things weigh in excess of 1650kg even if they don't feel like it.
I would like to replace the rotors with DBA xdrilled and slotted definatley front and depending on price rear too (at least machine the rear) and then some preformance pads.
what I need to know is are the stagea series 1 braking system the same as an R33 gtst or are they something different. Never owned a skyline before so i'm not sure. This will make getting the gear a lot easier than aksing people at stores. oh yeah and pads too, same as r33 ?????
thanks for the help
https://www.sau.com.au/forums/topic/103965-stagea-brakes-help/
I tested my brakes yesterday (new baby = very tired driver; would be better off drunk I reckon!).
They are GOLD. They stop hard & quick...... standard. As good as my DBA x-drilled/slotted rotors on my ex-VR V8 chaser sedan.
When they are worn, then I'll put slooted DBA's on the front, with good pads all round.
Brendan
Stagea brakes?
This car has the most pathetic brakes i have ever used. Even my 2tonne celsior braked harder then my stagea.
The stock pads overheat within 3-4 hard corners too (mountain stuff) which is also pathetic.
DBA's etc should make them "good", AP make them "mention worthy"
Each to their own though. For me, they overheat way too easy.
BAH HUMBUG! you guys obviously slow down too much for corners. In 18 months of Stagea driving I have always been able to activate the ABS at will. So the limit of retardation is the tyres, not the brakes. Good pads, slotted rotors and decent brake fluid is all mine needed.
:P cheers :)
:) cheers :)
Need better tyres? :P
Does anyone know what sort of money I would be looking at to upgrade the front to r33 gts-t calipers and DBA rotors.
Is it all a straight swap?
Maybe around ~500 for calipers all round, new rotors are 400 a pair, new pads are 200 a pair.
SK, even in straight line mega dry conditions, 100 to 0, i cant lock the ABS up. And ive got the braided lines too....
2nd time in the hills two nights ago, i consciously thought about not dragging the brakes, and being very quick with my braking. Wasnt getting very bad brake fade, not as bad as the first time.
I think maybe i have the el cheapo of cheap pads on mine, crapper then stock im talking :P
I'd think that mine has good pads, as they grip VERY well. I was very surprised I stopped so quickly. Biggest limiting factor is the $100 cheaparse tyres Im using (until someone finds me a set of 17inch R34 GTT wheels!! wink wink please)
Brendan
Yeah well I'm thinking of just going with a whole GTST upgrade. Front and Rear. It seems (after reading so many posts here) that doing anything with the standard brakes is just too hard as far as finding parts goes. At least with a whole R33 GTST setup I'll have better preformance and easier replacment of pads / rotors.
Has anyone here done this. And how much did it cost. I'm thinking R33 4 spot calipers front, 2 spot rear and matching rotors front and rear. Wether I go for slotted or not is a different matter depending on cost. Otherwise i'll upgrade rotors later.
I'm assuming pads and rotors are going to be much easier to find this way. Also how easy to fit the whole setup.
Thanks guys
Need better tyres?  :)
Nope and the suspesnion is pretty good too.
Don't forget the master cylinder and the hoses. Just sticking used callipers on is not my idea of a good move. I would look at rebuilding the callipers and master cylinder before I put them on. They may well be in worse condition than what you take off. Just changing the fronts only adds a complication, that being the master cylinder front/rear biasing will be wrong. That means differential bore sizes to fix, not a cheap conversion as it requires some braking system expertise (not your local workshop).
Last time I bough Nissan 4 spot fronts and 2 spot rears they cost $800 with used standard rotors, because the people selling them wouldn't separate. So I ended up with a set of rotors that I didn't need plus the $50 freight (they are heavy) to get them here. The prices are high because the Silvia guys all want to do the 5 stud + brake upgrade. Their strong demand pushes the prices up. I sold the standard rotors for $150 to get some money back.
Then I had to get the callipers serviced, that was $400 and new DBA slotted rotors where $700. Then I had to buy pads, decent pads, they were $450 for the set (front and rear). The standard brake hoses didn't fit, although they were in OK condition. So I made up a set of braided lines, they would have cost $320 trade price. Fortunately the master cylinder was the right size and I already had it rebuilt for $180.
Add it up;
800 + 50 - 150 + 400 + 700 + 450 + 320 + 180 = $2,750.
Plus the labour to remove and replace, I reckon no change from $3K.
Did it improve the braking, hell yes, but I reckon I could have achieved almost the same improvement with just rotors and pads for around 1/3 the cost. This is why I have gone that way with the Stagea.
:) cheers :)
Edited by Sydneykid
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
