Hi all, hoping some of you guys can answer a few questions for me.
Firstly, has anyone found a reputable source for bodykits for 4 door R32 GTS-T's? Specifically Vertex style kits?
Secondly, has anyone tryed to fit R33 GTR factory wheels to their 4 door? I know the wheels physically fit, but I would like to confirm how much work in terms of guard flaring/rolling would be realistically required to accomodate these wheels on the 4 door - assuming the car is lowered 1.5-2 inches all around.
Thirdly, R32 GTR rear seats in a 4 door - possible or impossible?
Cheers,
Nick :rofl:
https://www.sau.com.au/forums/topic/103997-calling-4-door-r32-owners/
"Secondly, has anyone tryed to fit R33 GTR factory wheels to their 4 door? I know the wheels physically fit, but I would like to confirm how much work in terms of guard flaring/rolling would be realistically required to accomodate these wheels on the 4 door - assuming the car is lowered 1.5-2 inches all around."
Ive got s15 rims on my car and its fairly low no probs with scrub biggest tyres I run are 225's
No worries Blitzeh :P
Try G-Force in syd, Avi Prasad is the bloke's name who runs it I think. He's on this forum, and I think he was looking at becoming a sponsor, dunno how he went with it. His website is http://www.jap.com.au in any case. The kits fit pretty well from the ones I've seen, and his prices are pretty damn good. The website has the coupe kit listed only, but I remember him mentioning the 4 door kit was in development last year, so it might be ready now.
Roll and flare of guards required in the front, might be able to get away with a roll only in the back. 4 Doors look tougher with flares all around anyways.
Possible, I've seen a few cars with em done... however the mounting positions don't line up exactly the same, some customising is required, and shutting the door is a little harder.
All possible... A group called Panteraftermarket (www.pantheraftermarket.com) do Vertex bodykits for 4 doors. Or Adrenalin Autosports as well, located in Sydney and Queensland respectively.
R33 GTR wheels will fit. Depending on your ride height, you might have to roll the guards, namely the rears. I had too.
And I also have an R32 GTR seat in my car... fit like a glove.
p.s Are you stalking me?? haha :rofl:
Here's Panther...
Panther Aftermarket
HEAD OFFICE
Unit 8 Industrial units
Crescent Head Road
KEMPSEY
PH: 02)6562-2556
FAX: 02)6562-2556
EMAIL: [email protected]
Bank Details for Direct Deposit
ACC Name: Panther Aftermarket
BSB: 032-580
ACC:146589
I'll have to get back to you with Adrenalin.
what are the offsets of R33 gtr rims?
ive got 18x9 +30 on the back of mine and they fit without any modifications. and my car is quite low... can just see the top of the tyre under the guard.
are the leather gts-t seats different to other gts-t and gtr seats? cos i tried puttin my mates leather seats in my car (cos mine where out and people needed to be driven places) and the backrest was too short
how do u roll the rears when theres no real guard to roll? theres like 2cm of panel that goers around the wheel
I had it done from group in richmond, just normal guard rolling machine. $50 a corner. It's not all the way round, they just rolled where the tyre would sit and a small surrounding area.
Heres an update for you all.
I have fitted R33 GTR wheels without a problem, mind you the car isnt lowered as yet, however the wheels have advan 225's which are undersized for these rims on a GTR, but work well for this application.
GTST: I had R32 GTR wheels on the car previously and noticed a bit of rub on turn, but havent as yet with the 33 GTR wheels - odd.
For some reason im really keen on the 4 door now and its my new project - so the hunt for parts continues!
    • How much have you lowered?  I had 350Z springs in the rear and was able to pull the camber into factory spec with the factory arms on the rear, obviously the front ran negative camber as it isn't adjustable, but rotating the wheels regularly evened out the wear.
    • Either the installer needs to come back, you need an auto electrician, or you need to learn automotive electricals yourself.   First step Id look at is where that big thing came out of, is there still things unplugged at that location? Maybe they just forgot to put a relay in or something?
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
