I am guessing a few of you knew of these cars but this is the first i have seen of them. I guess if i needed a family car i would either get one of these or a steaga :D
i know if i saw one at a set of lights i wouldnt even look twice <_<
http://www.prestigemotorsport.com.au/?/au/...sp?StockID=3771
https://www.sau.com.au/forums/topic/104018-a-nice-sleeper/
We got them locally as a Lexus something-or-other but only with the 2JZ-GE.
There are a couple of 2JZ-GTE ones in Australia, a guy had personally imported one from Japan about 2 years ago (was a 1999 model, looks alot better). Was a dark blue colour and used to prowl around ACT, havent seen it for a while.
They are awesome though, do the usual mods you would to a Supra and for less than $10k you have a 400kw family car :D
https://www.sau.com.au/forums/topic/104018-a-nice-sleeper/#findComment-1912857
The Aussie counterpart is a GS300 I think
It's a pretty cool trick for anyone that wants to do a 2JZ conversion...... Instead of forking out a shit load for a twin turbo supra front cut you pay 2 grand less and get basically the same thing in an Aristo front cut
https://www.sau.com.au/forums/topic/104018-a-nice-sleeper/#findComment-1913192
If you think that Aristo's are a nice car (as I do) then you will be interested to know that High perfomance imports magazine have bought one for thier new project car (the 2JZ -GTE type) should be a good read... :rolleyes:
https://www.sau.com.au/forums/topic/104018-a-nice-sleeper/#findComment-1916614
hmm sounds interesting if you come to jerra bring it along :rolleyes:
If you think that Aristo's are a nice car (as I do) then you will be interested to know that High perfomance imports magazine have bought one for thier new project car (the 2JZ -GTE type) should be a good read... :D
https://www.sau.com.au/forums/topic/104018-a-nice-sleeper/#findComment-1916658
    • Ok so will run the piping over that radiator and no plenum it is. Put that money towards a Haltech and see what suits. Any ideas something like an elite 2000 or 2500 right? My long term goal is 300kw e85 and manual swap and that’s a dream come true. For now will be 200kw and auto the stock rb25det neo intake isn’t too expensive with throttle body. If I was to have the port matching done, Would that be better than the stock de intake as the det has bigger holes plus has the spots for sensors etc? And suit more long term?  appreciate the advice?
    • You understand AFR is not the only thing that contributes to it pinging yeah? Funnily, what the AFR gauge will tell you when it likely is pinging, is going to make you think things are really safe and good.
    • Run the piping how we all have for decades. Also the duel runners with the +T setup dramatically helps it gets on boost quicker. Yes, chase huge power it'll become a problem, but you're a long way off when you're already saying an aftermarket ECU is out of the budget. You also say NisTune as it's simple, and then immediately say it'll be painful, meaning... It won't be simple. It will likely cost you a lot more stuffing around with a Nistune, than just putting a Haltech or similar in.
    • I’ll order an afr gauge to keep an eye on it.  Then will get a haltech soon
    • TD05 or maybe pulsar PSR2867r Gen 2?  id love a garret but it’s quite out the budget for now and I’m not chasing crazy power.    yeh fuel pump haven’t looked into but whatever works, kind of last on my list.    Nistune because it’s simple but Ik it’s a lot of pain especially as I’m auto +t with the whole seperate TCM etc still investigating that. Haltech id love but once budget tight for now atleast.    finally the reason I’m trying for a plenum instead of the stock intake is I already have a standard Intercooler mounted etc. so the ports are on both sides so trying to not have to go over the clutch fan radiator etc. trying to find a good deal return flow if I don’t than this will do for now I guess. btw any ideas with that, apparently some people have to cut blades to reduce it from hitting the Intercooler piping over the radiator ? Thanks
