After a month (~2,000k's) of running exclusively on Extreme in the R33GTST, I did a fuel filter change on the weekend. Cut it open and no sign of any foreign material, deteriorated fuel hose etc. That means zero effect from the 5% ethanol, as expected. So we will continue to use it.
:drag: cheers :D
WooHoo!!!! Been waiting on your diangnoses SK. You have confirmed what I thought. I did crack open my fuel filter and hoses last month after 20 tanks but wasn't sure what I was looking for.
Extreme kicks asse!!
  • 5 months later...
  • Replies 42
Current status, after 8 months of running exclusively Shell Optimax Extreme 100 ron.
After 3 fuel filter changes I still haven’t found one sign of fuel system rubber or metal deterioration.
I cleaned the injectors last week and there is not one sign of any effect on them either. I also flow tested them and they performed exactly as they did last time I flow tested them.
Based on the results with the R33GTST, I have now started to use it in the Stagea, which I will be tuning again very shortly to take advantage of the extra performance on offer.
>_< cheers :D
Edited by Sydneykid
:D cheers :)
Please post in Stag dyno results section, once done ! >_<
Pity we dont have 100ron here in SA (that I know of)
Ive gone back to BP 98 in liue of Mobil 98, find Im getting a few more kms from the tank
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
