hey mate, looks trick.  i just lost my licence due to street racing.  i have just ordered a carbon bonnet, trust body kit, low king springs, front mount intercooler, and have just bolted a 3" Cat back exuast on.
BUGGER about ya licence.
Im still waiting to see what happens with mine as i only had one point on porbabtion and i got caught speeding :(
have paid the fine but they didnt ask me to hand in my licence so playing it by ear!!!!
My Mrs would kill me if i lost it seeing as we only just bought a house <_<
Sounds like you have a few bits and piece's coming for your car, looking forward to hearing your progress!!!
Cheers GMB
https://www.sau.com.au/forums/topic/104103-r33-progress/#findComment-1926606
yeah, they took the cops impounded the car for 48 hours. i missed it like hell. yeah, im looking forward to the next meet up. seend quite a few trick skylines around, but not many stop to talk. wog boy has been a great help with my car. i owe him a lots of favors, has a great passon for skylines too!!!
https://www.sau.com.au/forums/topic/104103-r33-progress/#findComment-1928522
I havent done anymore power mods to it, only new front bar, and a few other small things inside, also cleaned up the engine bay... (took ages)... Well its all money i guess would love to do more to it if i could.
cheers. luke
Edited by NismoRB25
https://www.sau.com.au/forums/topic/104103-r33-progress/#findComment-1928816
yeah iv been talkin to ben a bit (his brother)
power - 219rwkw @ 18.5psi
Yeah, I know Ben really well... (since kinder)
geez, that's a fair but of power for what it is! I think it is one of those freak cars that just come out of the factory a beast! (asian dude building the engine was having a good day) :(
Would be good to see it again... This is what mine is looking like these days (just have to dump it when I move house!
Todd
https://www.sau.com.au/forums/topic/104103-r33-progress/#findComment-1932938
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
