hey i am looking for some of the stock intercooler piping for R32 RB20det.. the part that goes over the engine, and the part that comes off the turbo and goes down to the intercooler, called the "hotpipe".
Also the top half of the timing belt cover
I HAVE CROSS OVER PIPE IN NEWCASTLE
PAINTED BLACK PROBABLY HAVE OTHER PIPE TO IF YOU CAN JUST CLARIFY WHICH PIPE IT IS.ITS NOT THE ELBOW?THE PIPE OFF THE ELBOW TO TOP OF COOLER PIPE?
PM ME
ive got the timing cover 100 im in melbourne but :lol:
im in ADELAIDE, just an idea of prices:
D1 garage want $25 for the timing cover,
$45 for the crossover pipe.
im just being stinge and seeing if anyone will sell me theirs for cheaper!
in other words u want it for free :(
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
