Hey check out ebay au, happen to see a post of NGK G-Power platinum going for $5 buck with free shipping..
NGK G-Power
Another interesting thing to note, for R32 owners etc... the coil pack PLUGS (loom side), have a tendency to DESINTEGRATE... especially if they're 13-15 years old... I've seen this happen before, and today I changed my plugs (after having missing on 2 cylinders... sounded like a WRX :D) to copper BCPR6ES-11's gapped to 0.7mm, and had TWO stuffed coilpack plugs. She runs a charm now.
Even if the inside yellow/brown section of the coilpack plug desintegrates, DONT cut the plug off... you CAN NOT buy these new (as far as i know), and will have to source them off another wreck. They still work fine if the yellow/brown plastic comes out, just push the pins/resitors back in, and connect the plug carefully... no dramas! :)
i iused the BCPR6ES and had major missfire problems under boost which then killed the plugs so it sounded like scooby. i then replaced them with BCPR7ES and all is well. i have an R32 gts-t std boost but HKS air filter, exhaust including downpipe with bov.
Im in england by the way.
Thanks John
With regards to the V-Power.
They are a little difficult to get here in SA but I have found Motortraders stock the BCPR6E.
The BCPR6E are the V-power/groove plug. I believe they dropped the Y.
From memory a set of 6 from Motortraders is around $17.
Don't bother with supercrap they wanted 3x the price.
Dirt Cheap. :D
They are..
I've been running them since they were called BCPR6EY. Around 2-3years ago for some reason they dropped the Y.
So in total including the Y's I have been running them since I bought the car 4.5yrs ago.
I have an old spark plug laying around somewhere, I'll grab a pic of it and post her up.
But as I said the only place that stocks them is Motortraders, specifically Motortraders at Edwardstown. The BCPR6E-11's appear to be a little more abundant.
Here's a quick google result.
http://www.overboost.com/obs/hin/product.a...name=Sparkplugs
and this from an old NGK link.
http://66.102.7.104/search?q=cache:sSDfG7y...lient=firefox-a
I gave them a buzz as Im going to throw in a set of 7's in a couple of weeks.
Unfortunately they don't have the BCPR7E/BCPR7E-11 or BKR7E/BKR7E-11 listed, the BCPR6E's are.
Bugger..
EDIT: And a couple pics of the BCPR6E that have done 30,000km's.
They were still running fine in the car but you can see they were on their way out as the electrode is well and truley rounded. :whistling:
No octane boosters and the like only ever BP98.
Sweet. Good stuff they have the BCPR7E then!
And yeah those sparkies look well and truely shagged. Lucky their cheap!
What gap are you running? I've found I can gap V-Powers around 0.1 - 0.15 bigger than NGK Platinums which is a testimony to their efficiency.
Yeah actually come to think of it, I've never been able to get my hands on the 0.8mm version. Always the BKR7E-11. Kinda annoying. The guys in the States debate about gapping the -11s down to 0.8mm (or less) as they say the electrode isnt parallel anymore. Still works good though..
I've noticed this also when I gapped a set down, which is why until now I've avoided gapping down.
Couldnt you guys just order in a whole bunch, group buy it on here or something?
Im going to try and find them tomorrow tho, and do it on the weekend see how it goes and all.
Quick question tho. If my little sprung coilpack contact things are gone, but the coilpack other than that is still good, what would I use as a replacement for the spring?
Well my worst fears are confirmed, 3 of 3 coil packs I pulled out had cracks and tested at the 20k ohms setting 1.5,1.6 and 1.7, I have allready found some new ones at Kudos motorsport, has anyone bought from them and these are OEM units.
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
