I know i promised a drag meet for sometime in Jan but it looks as if it will have to be early mid march after pay day!!!
So are ppl still keen.
I know Leigh you still want a shot at the champ.... lol j/k
So this is a perfect time for all you 32 drivers that think you are the shit, to lay some rubber down and prove it!!!
When the weather cools a bit I also want to do a track day as well.
edit looks like i will be setting the date for sometime in april if all goes well. Just so Nick can come
Edited by race_snooze
https://www.sau.com.au/forums/topic/104580-wsid/
hmm very tempted though i cant even drive for another week and i still have a couple of things to do plus i wouldnt mind getting a new clutch its ok for normal driving but i dont think it would handle a wsid meet to well. Anyways if you all want to head up sooner thats cool but i might not be able to make it up till late march early april. Should be nice and cool then anyways :)
https://www.sau.com.au/forums/topic/104580-wsid/#findComment-1925472
Pfft like you need slicks to beat me :( if anyone should have slicks it should be me :)
Leigh
it looks like it will about march 22nd week after pay day.!!
Leigh get you arse into gear and get it ready.  I am going to get some 16"s with slicks I think.  Say good bye to rest of my clutch.
https://www.sau.com.au/forums/topic/104580-wsid/#findComment-1926581
Will see if the beast is back and run in by then but if I cant then maybe Jun, Myshy or Widebody may wish to represent the 32's ;)
I would like come to represent the 33's don't know about the 32's but i know JUN aint got much chop seen it go.
Would this be on a Sunday
https://www.sau.com.au/forums/topic/104580-wsid/#findComment-1936683
Are you serious, JUN ain't got much chop do you know what's been done to it. That thing is an animal and would blow any of us away. :P
I think GZ knows how much chop JUN has :) Id have to agree though, it wasnt even as quick as my stocker! :(
Definately come up Andre, trying my hardest to get the radiator back in the car for this.
EDIT: And on that note, is anyone keen on staying in Sydney that night? No where extravagent, but I couldnt be assed driving back at 10PM and its a good excuse for a friendly drink fest.
Edited by Amaru
https://www.sau.com.au/forums/topic/104580-wsid/#findComment-1937917
    • Get an inspection camera up there.
    • Yeah, but look at the margin in viscosity between the 40 and the 60 at 125°C. It is not very large. It is the difference between 7 and 11 cP. Compare that to the viscosity at only 90°C. The viscosity axis is logarithmic. The numbers at 90 are ~15 and ~35. That is about half for the 40 wt oil and <half for the 60. You give up viscosity EXPONENTIALLY as temperature rises. Literally. That is why I declare thicker oil to be a bandaid, and a brittle one at that. Keep the oil temperature under about 110°C and you should be better off.   Having said all of that, which remains true as a general principle, if you have indeed lost enough oil from the sump that the pump was seeing slightly aerated oil, then all bets are off. That would of course cause oil pressure to collapse. And 35 psi is a collapse given what you were doing to the engine. Especially if the oil was that hot and viscosity had also collapsed. And I would put money on rod or main bearings being the source of the any noise that registered as knock. Hydraulic lifters should be able to cope with the hotter oil and lower pressure enough to prvent too much high frequency noise, although I am willing to admit it could be the source.
    • Thanks for the reply mate. Well I really hope its a hose then not engine out job
    • But.... the reason I want to run a 60 weight is so at 125C it has the same viscosity as a 40 weight at 100C. That's the whole reason. If the viscosity changes that much to drop oil pressure from 73psi to 36psi then that's another reason I should be running an oil that mimics the 40 weight at 100C. I have datalogs from the dyno with the oil pressure hitting 73psi at full throttle/high RPM. At the dyno the oil temp was around 100-105C. The pump has a 70psi internal relief spring. It will never go/can't go above 70psi. The GM recommendation of 6psi per 1000rpm is well under that... The oil sensor for logging in LS's is at the valley plate at the back of  the block/rear of where the heads are near the firewall. It's also where the knock sensors are which are notable for 'false knock'. I'm hoping I just didn't have enough oil up top causing some chatter instead of rods being sad (big hopium/copium I know) LS's definitely heat up the oil more than RB's do, the stock vettes for example will hit 300F(150C) in a lap or two and happily track for years and years. This is the same oil cooler that I had when I was in RB land, being the Setrab 25 row oil cooler HEL thing. I did think about putting a fan in there to pull air out more, though I don't know if that will actually help in huge load situations with lots of speed. I think when I had the auto cooler. The leak is where the block runs to the oil cooler lines, the OEM/Dash oil pressure sender is connected at that junction and is what broke. I'm actually quite curious to see how much oil in total capacity is actually left in the engine. As it currently stands I'm waiting on that bush to adapt the sender to it. The sump is still full (?) of oil and the lines and accusump have been drained, but the filter and block are off. I suspect there's maybe less than 1/2 the total capacity there should be in there. I have noticed in the past that topping up oil has improved oil pressure, as reported by the dash sensor. This is all extremely sketchy hence wanting to get it sorted out lol.
