  • Replies 48
I cant believe how full of "it" some people are!
AND... I cant believe what I am reading!
There is nothing wrong with and never will be anything wrong with modding an "ageing" car and anyone who says that it is a money pit or a time sink is kidding themselves!
eg:
*R31 Aus spec 4 door average purchase price $3000 - $5000 for a good one.
*R32 Gtst Import - $10000 - $16000 for a good one.
*R33 Gtst Import - $16000 - $21000 for a good one.
*R34 GTT Import - $24000 - $30000 for a good one.
Consider those prices as a stock car purchase (no mods) now...
I know R31's and if anyone wants to argue that point PLEASE DO!
A good R31 RB25DET conversion can be done for under $7000 I know because I did one!
As for the brakes and suspension - The brakes dont need major upgrading unless the car is going to see track every now and then just a good set of High temp pads and slotted rotors is enough plus the obvious things like new fluid, wheel bearings and mabye a caliper rebuild, all up - under $1000.
Suspension - Bushes $500 for a full set of urathanes - Fitted, Lowered springs $150 an end and shocks $200 an end.
As for engineering ($600 at the most) - you shouldnt have problem passing it with those mods as long as nothing has been done "bodgy" and the car is road worthy.... Once again I know because I have done it!
All up if the cars exterior is in good condition which isnt rare you shouldnt need to do much else to it apart from maby service or rebuild the diff - $750.
SO - For uner $14000 you will have a VERY nice R31 with ALOT of sleeper apeal and it will be great to drive (and it will upset alot of V8 boys from the lights).
Where as if you buy a later model like a 32 and put an RB25DET in it you will have already spent at least $17000 buying the car and front cut.
So Gus If you want to do it then BLOODY WELL DO IT!
People said that I was an idiot for building my car but look at what it is today and the benifit of it all is that not every joe and his dog has a modified 31 (unlike certain other Skyline models).
Oh and Gus - If you need help with any Parts or work at all let me know cos I can get anything for very cheap (which means it will all be cheaper again) and there is nothing I cant do to a 31.
There Ive said my piece....Now i sit back and wait for the fall out.
Yayyyyyyy!! congrats Gus!!
Getting your first car is the best feeling ever
Yes, it is a Box R31 but hey, its all mine thanks to my brother and his generosity. it's a stock, auto,  white executive, with one flat tyre.
generosity of your brother? is he giving it to you?! :P
eg:
Shut up mick.
Anyways I forgot to mention gus young lad, I will give you a hand with any work you need help with!
Oh and R31 coupes are cooler so lets weld the back doors! :lol:
Hey Gus, i've got plenty of spare parts if you need any to borrow to get over rego... Just ask Bluprint/Mark about my stock :mellow: I'm in tuggeranong as well, from the sounds of it you are as well.
And... Go all out on mods, don't buy cheap shit here and there and plan a bigger upgrade later. Just get the top range stuff and regret it later.
Edited by StinkyPoo
yeah stinkypoo i see you on R31 club, your silo is nice.
at the moment, ive gotta get rego check and see what needs doing with what, then do myself a little write up of my finances and stuff, see if i wana put some money into it and have me a nice first car, or if i wana save my money and go for a really nice car by the end of the year!
and yes shell he did give it to me :P
eg:
HA! remind me again why you want to up-grade???
pfff, as if weld doors to make it look like a coupe, 4door AUS spec is where its at -i sold my gt passage so i could go aus again!
good stuff gus, dont let anyone tell you its not worth doing up, and btw, 300 000kms on a RB30 engine is NOTHING. u got at least unuther 200 000, probly more.
-Tom
Edited by kossak
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
