  • Replies 48
I cant believe how full of "it" some people are!
AND... I cant believe what I am reading!
There is nothing wrong with and never will be anything wrong with modding an "ageing" car and anyone who says that it is a money pit or a time sink is kidding themselves!
eg:
*R31 Aus spec 4 door average purchase price $3000 - $5000 for a good one.
*R32 Gtst Import - $10000 - $16000 for a good one.
*R33 Gtst Import - $16000 - $21000 for a good one.
*R34 GTT Import - $24000 - $30000 for a good one.
Consider those prices as a stock car purchase (no mods) now...
I know R31's and if anyone wants to argue that point PLEASE DO!
A good R31 RB25DET conversion can be done for under $7000 I know because I did one!
As for the brakes and suspension - The brakes dont need major upgrading unless the car is going to see track every now and then just a good set of High temp pads and slotted rotors is enough plus the obvious things like new fluid, wheel bearings and mabye a caliper rebuild, all up - under $1000.
Suspension - Bushes $500 for a full set of urathanes - Fitted, Lowered springs $150 an end and shocks $200 an end.
As for engineering ($600 at the most) - you shouldnt have problem passing it with those mods as long as nothing has been done "bodgy" and the car is road worthy.... Once again I know because I have done it!
All up if the cars exterior is in good condition which isnt rare you shouldnt need to do much else to it apart from maby service or rebuild the diff - $750.
SO - For uner $14000 you will have a VERY nice R31 with ALOT of sleeper apeal and it will be great to drive (and it will upset alot of V8 boys from the lights).
Where as if you buy a later model like a 32 and put an RB25DET in it you will have already spent at least $17000 buying the car and front cut.
So Gus If you want to do it then BLOODY WELL DO IT!
People said that I was an idiot for building my car but look at what it is today and the benifit of it all is that not every joe and his dog has a modified 31 (unlike certain other Skyline models).
Oh and Gus - If you need help with any Parts or work at all let me know cos I can get anything for very cheap (which means it will all be cheaper again) and there is nothing I cant do to a 31.
There Ive said my piece....Now i sit back and wait for the fall out.
Yayyyyyyy!! congrats Gus!!
Getting your first car is the best feeling ever
Yes, it is a Box R31 but hey, its all mine thanks to my brother and his generosity. it's a stock, auto,  white executive, with one flat tyre.
generosity of your brother? is he giving it to you?! :P
eg:
Shut up mick.
Anyways I forgot to mention gus young lad, I will give you a hand with any work you need help with!
Oh and R31 coupes are cooler so lets weld the back doors! :lol:
Hey Gus, i've got plenty of spare parts if you need any to borrow to get over rego... Just ask Bluprint/Mark about my stock :mellow: I'm in tuggeranong as well, from the sounds of it you are as well.
And... Go all out on mods, don't buy cheap shit here and there and plan a bigger upgrade later. Just get the top range stuff and regret it later.
Edited by StinkyPoo
yeah stinkypoo i see you on R31 club, your silo is nice.
at the moment, ive gotta get rego check and see what needs doing with what, then do myself a little write up of my finances and stuff, see if i wana put some money into it and have me a nice first car, or if i wana save my money and go for a really nice car by the end of the year!
and yes shell he did give it to me :P
eg:
HA! remind me again why you want to up-grade???
pfff, as if weld doors to make it look like a coupe, 4door AUS spec is where its at -i sold my gt passage so i could go aus again!
good stuff gus, dont let anyone tell you its not worth doing up, and btw, 300 000kms on a RB30 engine is NOTHING. u got at least unuther 200 000, probly more.
-Tom
Edited by kossak
    • Get an inspection camera up there.
    • Yeah, but look at the margin in viscosity between the 40 and the 60 at 125°C. It is not very large. It is the difference between 7 and 11 cP. Compare that to the viscosity at only 90°C. The viscosity axis is logarithmic. The numbers at 90 are ~15 and ~35. That is about half for the 40 wt oil and <half for the 60. You give up viscosity EXPONENTIALLY as temperature rises. Literally. That is why I declare thicker oil to be a bandaid, and a brittle one at that. Keep the oil temperature under about 110°C and you should be better off.   Having said all of that, which remains true as a general principle, if you have indeed lost enough oil from the sump that the pump was seeing slightly aerated oil, then all bets are off. That would of course cause oil pressure to collapse. And 35 psi is a collapse given what you were doing to the engine. Especially if the oil was that hot and viscosity had also collapsed. And I would put money on rod or main bearings being the source of the any noise that registered as knock. Hydraulic lifters should be able to cope with the hotter oil and lower pressure enough to prvent too much high frequency noise, although I am willing to admit it could be the source.
    • Thanks for the reply mate. Well I really hope its a hose then not engine out job
    • But.... the reason I want to run a 60 weight is so at 125C it has the same viscosity as a 40 weight at 100C. That's the whole reason. If the viscosity changes that much to drop oil pressure from 73psi to 36psi then that's another reason I should be running an oil that mimics the 40 weight at 100C. I have datalogs from the dyno with the oil pressure hitting 73psi at full throttle/high RPM. At the dyno the oil temp was around 100-105C. The pump has a 70psi internal relief spring. It will never go/can't go above 70psi. The GM recommendation of 6psi per 1000rpm is well under that... The oil sensor for logging in LS's is at the valley plate at the back of  the block/rear of where the heads are near the firewall. It's also where the knock sensors are which are notable for 'false knock'. I'm hoping I just didn't have enough oil up top causing some chatter instead of rods being sad (big hopium/copium I know) LS's definitely heat up the oil more than RB's do, the stock vettes for example will hit 300F(150C) in a lap or two and happily track for years and years. This is the same oil cooler that I had when I was in RB land, being the Setrab 25 row oil cooler HEL thing. I did think about putting a fan in there to pull air out more, though I don't know if that will actually help in huge load situations with lots of speed. I think when I had the auto cooler. The leak is where the block runs to the oil cooler lines, the OEM/Dash oil pressure sender is connected at that junction and is what broke. I'm actually quite curious to see how much oil in total capacity is actually left in the engine. As it currently stands I'm waiting on that bush to adapt the sender to it. The sump is still full (?) of oil and the lines and accusump have been drained, but the filter and block are off. I suspect there's maybe less than 1/2 the total capacity there should be in there. I have noticed in the past that topping up oil has improved oil pressure, as reported by the dash sensor. This is all extremely sketchy hence wanting to get it sorted out lol.
