Hey guys, I saw this boost controller on the Hikari website and a few others, yet i havent found any other info on them in regards to how they preform compared to the way more expensive Jap brands. FYI Hikari are sellin them for 320. Thats a fully electronic Dual stage boost controller that has in cabin control. Seems to good to be true. It also looks quite nice and looks like it would fit snug in the position of the ash tray (which is good as im not a smoker).
If anyone can shed any light on this product whether its reliable and how it preforms, etc, it would be greatly appreciated.
Thanks
http://www.hikariperformance.com/new_electronics.htm
(scroll rite to the bottom)
https://www.sau.com.au/forums/topic/10481-hybrid-electronic-boost-controller/
I was told but am not 100%sure that they are like a electronic version of the turbosmart type 2 stage bleed valve setup, so they are not as accurate as controlling boost like good elec ones they just give you control in the cabin.
They are nothing like the TS twin stage they do run a micro processor
seen in two cars now work well but you need to have a map sensor of some type ..... like you need to tap into say the std dash map on r32/33 but on somthing like a s13 you'll need to hunt a map sensor down
I sent power digger an email.
Heres what i sent:
Hi
I wondering if you could supply me with as much info as u can on the Hybrid fully electronic boost controller. How does it work through the microprocessor? Is it like an AVCR, or not as indepth and efficient. Will it hold high boost levels, and will the boost levels spike due to it being a bleed valve type boost controller. Im very serious on buying one, just want more info before i make my decision.
Thanks
Dean
And heres his reply
thanks for your interest it has a micro built in and by sensing the boost signal the micro calculate the right boost amount
in other words it try to bring the boost up to preset level as soon as possible and soon after it reaches the preset boost it regulated it
never over shoot
beside it is not a bleed type valve it is a proper 9 bar solenoid valve that uses in many other Japanese boost controller
Thanks
  • 3 weeks later...
Hi all,
I have installed the hybrid boost controller. I have to say it was the easiest ebc install(just three wires, the same three that run to the factory boost reciever in the engine bay) i have ever done!!
Very easy to tune, just set the dials for hi/low boost.
On the road it holds boost and at 20psi is only only slightly shaking the needle on the boost gauge (not more than half a psi either way.
As for brining boost on earlier I noticed a little differance
install 9/10
tunability 10/10
boost holding 8/10 (twin solonoid would have been better)
Appearance 4/10 (only one blue led and no screen as per avcr)
All in all not bad for $325 delivered
  • 3 weeks later...
Hi There,
I also noticed the "powerdigger" at UAS (for $380).
Seems like a really good buy.
Quick question for those who have installed it.
- Does the car fill "jerky" when on full boost as some one mentioned that is was changing half a psi up and down (at 20 psi).
I am only planing to run 12 psi, will I notice it? How smooth is it under boost?
- when it comes to installing it, where is the "map sensor" or "boost sensoe" what ever it is called... I should have no problems installing it just need to find that boost sensor (for an R33 gts-t)
Thanks for your answers.
Regards
Rob
Hi Rob the car is not jerky when on boost, even though the boost needle is moving. When you get the intstructions it has a picture of the boost sensor and how to wire it all up. The boost sensor should be on the left hand side of the firewall. easy to spot if you know what your looking for.:)
If anyone else has installed one please write your comments, as I wonder if it is any differant on a smaller tubo, unlike mine which has a fair bit of lag.????
Ps go to hikari they are $325 delivered
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
