Andrew... I too await adsl2, hopefully there's no issues, I suspect there may be though. :S
1283kilobits is roughly 160kb/s. So pretty spot on for a 1.5mbps connection.
Take the speed testers with a pinch of salt...
I would consider Adam or Internode.
Adam if you simply check email + a little web browsing.
Internode if you want an all round excellent service that is always up with awesome international speeds.
Do remember you get what you pay for... You can't go past internode when it comes to their service and quality. Well worth the few extra $$.
https://www.sau.com.au/forums/topic/105092-adel-isp/page/2/#findComment-1938282
I'm with EFtel. Crap service, for example, when we connected there was some stuffup with my friend getting charged twice, and it took three different people to rectify it, but other than that.. good. The best part - 512/128 ADSL, NO limit, NO shaping. 70 bucks a month :) If you're a big downloader, they're one of the few companies that don't shape the bandwidth.
https://www.sau.com.au/forums/topic/105092-adel-isp/page/2/#findComment-1938338
andrew, where is your nearest exhange?
Duc, we're about 2km from the exchange, which is "planned" with internode.
Problem is that Northgate runs off RIMs - we had to wait ages for ADSL to be available at all.
https://www.sau.com.au/forums/topic/105092-adel-isp/page/2/#findComment-1938853
thats disappointing and frustrating to say the least. the 'planned' exchange wouldnt happen to be gepps cross would it? a few of my mates and i are waiting to be ported over to adsl2+ but are being pending on some issues being recified or sorted by telstra.
https://www.sau.com.au/forums/topic/105092-adel-isp/page/2/#findComment-1938917
i was actually thinking of changeing my home telstra cable to adam over the next month.....
same im on cable but thinking ADSL2+ but im right on the max about 4kms from exchange so i need to hear from sum1 @ same distance and wot speeds they get d/ling
Sorry, but access to this feature is restricted to Internode Customers.
Internode 1,500/256 20Gb $59.95 waiting for DSL2+ to be available (hopefully but unlikely - rim hardware issues).
1283 / 110 on the Internode speed test. Seems low.
if ur on a RIM thats ok so long as where the RIM box is there is full copper cable into that Internode can do a Transposition Order and try to get u moved onto a proper copper phone line
Test run on 13/2/2006 @ 12:06 A.M.
Mirror: Bigpond
Test type: Cable
Your connection speed:
kbps: 8592.5
KB/s: 1074.0625
Mbps: 8.39111328125
from here
http://www.ozspeedtest.com/
edit and node server
Test run on 13/2/2006 @ 12:09 A.M.
Mirror: Internode
Test type: Cable
kbps: 9123.4
KB/s: 1140.425
Mbps: 8.9095703125
which if i keep refreshing Bigpond will give me that also i allways get 1173kbps of there file servers
Test run on 13/2/2006 @ 12:12 A.M.
Mirror: Netspace
Test type: Cable
kbps: 9249.9
KB/s: 1156.2375
Mbps: 9.03310546875
Edited by Madaz
https://www.sau.com.au/forums/topic/105092-adel-isp/page/2/#findComment-1943757
I'm 4.7km's via road from my exchange.
With regards to obtaining an adsl capable phone line another option is to order an ADSL Essential phone line where they connect up another phone line only if its adsl capable. If not they simply pull out and you get charged nothing.
Hope that makes sense... I've just woken up. :D
https://www.sau.com.au/forums/topic/105092-adel-isp/page/2/#findComment-1943857
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
