roflmao... J-Spec is not responsible for problems caused to relationships by the cars we supply.
As long as the credit card is free for her to use, it will be all good.
Don't you have a "REAL" job .. how the hell can you find enough time to buy 2 cars in the one week ?????
Unfortunitly I work with WiZardOz (Gary), well we sort of work
I wish you would hurry up and buy my R33 so we can turn it into a race car!
  • 3 months later...
Finally got news my car is leaving Japan and should arrive on the 30th May
It has only been about 4 months sitting in Japan waiting for a boat
I have a pile of bits waiting to go on, so I can not wait
As big Kev use to say "I'm excited"
here is a link i found i havent looked into it yet but its sposed to be able to track ships etc have a look see cos if you nkow the ships name i think this will tell u where she is .http://www.sailwx.info/shiptrack/
  • 3 weeks later...
Finally got my car today
Had it delivered this avro to my house
Will send it to compliance in the next week or 2
Need to remove a few aftermarket things first
After sitting around the docks for 3-4 months, it could do with a good clean
Need a bit of a tidy up
Small rust spot on door under RH mirror and bodykit could do with a few screws
Rear carpet in hatch area has some damage, will need to replace it
It is a fair bit different to drive than my R33 manual
Feels a bit sluggish with auto and extra weight
Will have to work on this
Let the mods begin :dry:
any that u have taken since you took delivery of it?
you can get an R34 GTR for about 60k if you import it............. :drools: ...... my dream car
No, camera is in getting repaired
What ever that thing is on the dash, someone else wanted it more
It went missing
34gtr
Me likes this one
http://www.j-spec.com.au/list/index.php?ID=6418
  • 1 month later...
Well. after nearly 6 months to the day from when I first paided for the Stagea, I went toget it registered today.
Went to get a RWC, could not get the car on the hoist due to the side skirts, so the mechanic said "Ahh, it should be fine under there"
Went to check the front lights, the front parkers were not working, mechanic said "You will get around to fixing them"
So with the RWC out the way, I went to the QLD department of transport.
Filled out the right forms, waited another 30min to get served, went out side to get the vehicle checked. the lady could not read the engine number, so I read it out for her because it was too had to read. Luckly I had rembered the engine number from before hand.
Went back inside with paper work inhand, she went thru everything, went off to talk to the supervisor and came back to tell me I needed the original import approval, not a copy.
I got staight onto the phone to IAMSHE to ask for it. Phil advised me that after doing over 600 cars in QLD they never once need the original, a copy was fine.
So it did not matter what I said they would not register it. I will have wait another 2 days to get the original and then it should be on the road.
I have been waiting 6 months now, so what is another 2 days :wave:
I had the same question asked and all I had was the copy, which they accepted in the end but in reality in the hands of whom ever you meet at the counter. I was in there for near on 2 hours while they tried to work out what they were supposed to do so I had a bit of luck I think... I waited 3 solid months for my car to get here and I would have been fuming if I had missed rego because of a photocopy or fax of an import approval (how would the car have cleared customs without that?) that sort of stuff really sh*ts me!
Hope you get it sorted soon!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
