Camshafts
Guest Nismo_Freak
What kind of gains are seen from a bump in duration and lift?
RB26DETT
Say using the 272 duration / 10.5mm lift, w/ valve springs on a fairly standard motor using only intake, 12 psi boost, full turbo back exhaust, fmic, and a HKS AVC (the fuel controller).
I would also swap the cam gears for adjustables and go with a 4 degree retard on the exhaust with a 1 degree advance on the intake.
Assuming fuel was optimized for the added airflow and tuned properly.
https://www.sau.com.au/forums/topic/10527-camshafts/
The gains are huge, it will be one of the most important factors in getting huge horsepower. Without decent cams then the potential of any turbo is not used. I would only tend to use cams like that with a bigger turbo, but even without it a 10-15% increase in power is possible.
See'ya:burnout:
https://www.sau.com.au/forums/topic/10527-camshafts/#findComment-168818
Guest Nismo_Freak
Sounds about right I suppose... the camshafts only increase the efficiency of the motor at the higher revolutions with a slight drop at lower rpms. This in turn creates lag as noted. But the end result is more power produced at lower boost levels. The requirement for octane however goes up because the dynamic compression increases, the same when boosting more. I just needed some numbers to go by. The stock cams are as follows, I believe:
Intake: 240 duration w/ .338 lift (8.58mm)
Exhaust: 236 duration w/ .326 lift (8.28mm)
The use of the cam gears will allow me to maintain the midrange and gain back some of the boost threashold lost when I moved to the hotter cams.
https://www.sau.com.au/forums/topic/10527-camshafts/#findComment-170233
The 272's will kick in at around 4000+rpm and give the motor more legs to 8000+rpm. Something around 250 or so duration would be a better choice for a streeter. I think there are a few around 254 duration.
Most aftermaket cams need to 'dialed in' according to the motor. The factory usually designs them for a 0 deg fit but, depending on what you have done they may benifit with various timing settings.ie: don't take 4 degrees as gospel if you use non factory cams.
https://www.sau.com.au/forums/topic/10527-camshafts/#findComment-170393
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
    • I believe @Duncan has given it a crack at Mt Buller before (in actual race conditions)
