Camshafts
Guest Nismo_Freak
What kind of gains are seen from a bump in duration and lift?
RB26DETT
Say using the 272 duration / 10.5mm lift, w/ valve springs on a fairly standard motor using only intake, 12 psi boost, full turbo back exhaust, fmic, and a HKS AVC (the fuel controller).
I would also swap the cam gears for adjustables and go with a 4 degree retard on the exhaust with a 1 degree advance on the intake.
Assuming fuel was optimized for the added airflow and tuned properly.
https://www.sau.com.au/forums/topic/10527-camshafts/
The gains are huge, it will be one of the most important factors in getting huge horsepower. Without decent cams then the potential of any turbo is not used. I would only tend to use cams like that with a bigger turbo, but even without it a 10-15% increase in power is possible.
See'ya:burnout:
https://www.sau.com.au/forums/topic/10527-camshafts/#findComment-168818
Guest Nismo_Freak
Sounds about right I suppose... the camshafts only increase the efficiency of the motor at the higher revolutions with a slight drop at lower rpms. This in turn creates lag as noted. But the end result is more power produced at lower boost levels. The requirement for octane however goes up because the dynamic compression increases, the same when boosting more. I just needed some numbers to go by. The stock cams are as follows, I believe:
Intake: 240 duration w/ .338 lift (8.58mm)
Exhaust: 236 duration w/ .326 lift (8.28mm)
The use of the cam gears will allow me to maintain the midrange and gain back some of the boost threashold lost when I moved to the hotter cams.
https://www.sau.com.au/forums/topic/10527-camshafts/#findComment-170233
The 272's will kick in at around 4000+rpm and give the motor more legs to 8000+rpm. Something around 250 or so duration would be a better choice for a streeter. I think there are a few around 254 duration.
Most aftermaket cams need to 'dialed in' according to the motor. The factory usually designs them for a 0 deg fit but, depending on what you have done they may benifit with various timing settings.ie: don't take 4 degrees as gospel if you use non factory cams.
https://www.sau.com.au/forums/topic/10527-camshafts/#findComment-170393
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
    • Probably. I take it that they are also mentioned to be for R34 Skyline? For example.... RDA has that part as RDA7957. I have the dimpled and slotted version of that on my car https://www.ebay.com.au/itm/285518478694?srsltid=AfmBOopKxMuAFpsxZJdB1cam4D5RAj1f9yJyOttPZLAwXVNCOiwlhrIy This is DBA's top one piece equivalent https://www.ebay.com.au/itm/364246686631?srsltid=AfmBOorbb0XHQgqTvZLgQPhg70nqJtGvdojKnugum3O2LFSr2h-obp8D
