hi all i think i have a big problem on my hands, i own a nissan silvia with a rb20 motor now i got the car with the motor and it had rego. now the rego is close to been up and i went over all the car to make shore its all ok. i didnot think much of it when i got the car as it all lind up the number and all but now when i ahd a chance to think abit a found that the rego sticker says that the engine number is ca18%$#@ now i am not shore but i think the number should start with rb20 or so if its regoed with this number
now i did find a number next to the gear box and it also says ca18%$#@ is that where the rb20 engine number is and if so should it start with rb20 or ca18
i think the number has been changed and if so what can i do make it right
plz help
pm if you have any idea thanx
Edited by 2bevil
https://www.sau.com.au/forums/topic/105396-rb20-engine-numbers-where-are-they/
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
