can it affect fuel economy?
i noticed in another thread that a guy got an extra 50/100 ks to a tank of fuel by replacing his charcol cannister
my fuel economy is attrocious and i know my charcol cannister isnt hooked up . .. .
https://www.sau.com.au/forums/topic/105461-charcol-cannister/
  • Replies 77
was reading on another forum that
before i was gettin like 300, until i replaced the charcole canister.. seems to better now..
ive replaced my o2 sensor and fuel economy hasnt changed from 300ks a tank (regardless of how i drive, regardless of low or high boost)
gets slightly better with highway driving
Is the speedo correct? As Im guessing thats the only way you can tell your kms. That or you might have a fuel leak... Maybe. Done all the injector cleaning etc?
[edit]
I dont think a charcoal canister will affect things that much either. I mean mine isnt hooked up, yet Im on 535kms and my fuel light isnt on yet...
yer, speedo is correct, havent done injector clean, but will do
was really hoping the o2 sensor woudl fix economy, but its made no difference at all
strong fuel smell reversing the car up the driveway, and apparently it did have a fuel leak, but piping was repaired
cant smell fuel in the boot at all though
Could be somelike like an injector seal? Who knows dude.
But a charcoal canister has to do with the emmissions control. It is illegal to have it disconnected. Has something to do with fuel vapour or something from memory. Dont quote me on that tho.
I have the same problem with my GTT...went at most 360km full tank...haven't done anything..but I'm going for the power Fc approach..
I'll be tuning my car on the 21st...will prolly know the difference with the fuel consumption a week after..I'll keep update..
My car uses a hell of a lot of fuel compaired to other cars as well. I normally get between 300/350 city driving and 400 highway.
Even when we drove to cairns, the car still only got 400km per tank. Yes admittedly there were places where we weren't doing the speed limit... but I still would have thought that it would have got more than 400k per tank :S
yup, that sounds about the same as mine
i dont get why we are getting such bad economy, yet other skylines making more power in some cases, get much better economy
the bloody car costs me enough as it is, just keeping it on the road, would be nice to get a petrol break, and squeeze an extra 100ks out of the tank
Maybe get a PFC retune?? My new car has a PFC and I get awesome ecconomy (411ks out of 35 L :D ) The new car gets no fuel smell at all where as the R33 you could smell it all the time (Stock ECU) I think engine managment would be the main factor that effects fuel ecconomy
what power you making bunta?
retune :D
wifey wont like it;
ive already spent hundreds of dollars on tunes (switched exhaust, retune was another 300 on top of the origianl 600)
surely for that amount of money, it wouldnt just be a power tune :)
was done at mercury
Edited by Spook's_Skyline
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
