can it affect fuel economy?
i noticed in another thread that a guy got an extra 50/100 ks to a tank of fuel by replacing his charcol cannister
my fuel economy is attrocious and i know my charcol cannister isnt hooked up . .. .
https://www.sau.com.au/forums/topic/105461-charcol-cannister/
  • Replies 77
was reading on another forum that
before i was gettin like 300, until i replaced the charcole canister.. seems to better now..
ive replaced my o2 sensor and fuel economy hasnt changed from 300ks a tank (regardless of how i drive, regardless of low or high boost)
gets slightly better with highway driving
Is the speedo correct? As Im guessing thats the only way you can tell your kms. That or you might have a fuel leak... Maybe. Done all the injector cleaning etc?
[edit]
I dont think a charcoal canister will affect things that much either. I mean mine isnt hooked up, yet Im on 535kms and my fuel light isnt on yet...
yer, speedo is correct, havent done injector clean, but will do
was really hoping the o2 sensor woudl fix economy, but its made no difference at all
strong fuel smell reversing the car up the driveway, and apparently it did have a fuel leak, but piping was repaired
cant smell fuel in the boot at all though
Could be somelike like an injector seal? Who knows dude.
But a charcoal canister has to do with the emmissions control. It is illegal to have it disconnected. Has something to do with fuel vapour or something from memory. Dont quote me on that tho.
I have the same problem with my GTT...went at most 360km full tank...haven't done anything..but I'm going for the power Fc approach..
I'll be tuning my car on the 21st...will prolly know the difference with the fuel consumption a week after..I'll keep update..
My car uses a hell of a lot of fuel compaired to other cars as well. I normally get between 300/350 city driving and 400 highway.
Even when we drove to cairns, the car still only got 400km per tank. Yes admittedly there were places where we weren't doing the speed limit... but I still would have thought that it would have got more than 400k per tank :S
yup, that sounds about the same as mine
i dont get why we are getting such bad economy, yet other skylines making more power in some cases, get much better economy
the bloody car costs me enough as it is, just keeping it on the road, would be nice to get a petrol break, and squeeze an extra 100ks out of the tank
Maybe get a PFC retune?? My new car has a PFC and I get awesome ecconomy (411ks out of 35 L :D ) The new car gets no fuel smell at all where as the R33 you could smell it all the time (Stock ECU) I think engine managment would be the main factor that effects fuel ecconomy
what power you making bunta?
retune :D
wifey wont like it;
ive already spent hundreds of dollars on tunes (switched exhaust, retune was another 300 on top of the origianl 600)
surely for that amount of money, it wouldnt just be a power tune :)
was done at mercury
Edited by Spook's_Skyline
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
