the only place that i have seen iton the coast is at shell currimundi, and i wasnt going to pay $1.38/L just to cruise around town so i gave it a miss, if it did give u a power gain id put it in to go to the track or sumthing if i ever was, but in my opinion it isnt worth it for round town driving.
I sometimes think that people don't get it....You don't have to retune your car to get benefits from it. If you have the stock ECU you can reset it to modify the settings to suit the new fuel. If you have a powerFC or something similar you don't have to go to a dyno and get it run again...that's just stupid. The 5% of ethanol will not harm your engine in any way as it's NOT splash blended, it's refined that way and, therefore, is not that same as just adding straight ethanol. A lot of you have been reading all that crap about E10....Optimax extreme 100 is not E10.....E10 is a 10% blend and can effect some of the newer cars. Due to the fact that it wears runbber out slightly faster than normal fuel....that doesn't mean that running a few tanks of it is gonna make your engine explode. And because the new 100 ron is only 5% it has even less of an adverse effect than the E10. I have run several tanks of the 100 and have noticed a couple of things...My car runs borderline tuning and will ping extremely heavily on 95 (premium unleaded) so I have to run the BP ultimate which is 98. I have to say be careful as I have found that some BP's are actually putting premium into their Ultimate tanks so be aware of this. On a hot day, sometimes the car will ping when using the 98....using the 100 stops it and it doesn't ping at all....ever. The second thing I noticed was fuel economy went crap. I used it up twice as fast as the 98.
Running a higher octane fuel will give added power gains whether you believe it or not....that is fact. It will decrease the likelyhood of detonation so protects your engine that little bit more.
i agree with u dan, only thing i was talking about is to me ( a owner of a stock R33 gtst) i dont think its worth it 2 pay $1.28+ a litre for me to drive my car around town when in actual fact im not racing any1 or trying to get my car down the strip quicker or gain more h.p. for round town driving, so i wouldnt buy it, there is no need for me to atm. but if i was on the dyno or trying to gain power, drags, etc i definately would try it. its gota make sum difference over all.
If shell says it is not to be used on nissans made before 2004 there must be a reason. it may not be that it makes it run like a dog or lose power maybe it can have long term effects too.
Shell only say that because Nissan told them to. They had to get approval from all car manufacturers and issue a statement to confirm whether that manufacturer would allow it. Fact is that ethanol eats away at rubber. The rubber which makes up the fuel lines and the rubber seals in your injectors. It also burns leaner and dryer. It only has adverse effects in a more than 10% mix though and even at 10% it would take like 10 years to damage an injector and you would have to be constantly running it through the system. The shell 100 is not potent enough to have any of these effects whatsoever.....the statement which was issued regarding all car manufacturers was in relation to E10 which is a more concentrated mix.
It will use more fuel as Ethanol like Methenol or any alcohol fuel is no where near as burn efficient-my old methanol dragster(99.5% methanol) would use double the fuel a hydrocarbon burning dragster (c16, unleaded or whichever) would use.
    • Place the new daughterboard in the case and mount it using the 3 small black rivets provided, and reconnect the 3 factory ribbon cables to the new board Then, use the 3 piggyback cables from the daughterboard into the factory board on top (there are stand offs in the case to keep them apart. and remember to reconnect the antenna and rear cover fan wires. 1 screw to hold the motherboard in place. Before closing the case, make a hole in the sticker covering a hole in the case and run the cable for the android unit into the plug there. The video forgot this step, so did I, so will you probably. Then redo the 4 screws on back, 2 each top and bottom, 3 each side and put the 2 brackets back on.....all ready to go and not that tricky really.
    • Onto the android unit. You need to remove the top screen because there is a daughterboard to put inside the case. Each side vent pops out from clips; start at the bottom and carefully remove upwards (use a trim remover tool to avoid breaking anything). Then the lower screen and controls come out, 4 screws, a couple of clips (including 3 flimsy ones at the top) and 3 plugs on the rear. Then the upper screen, 4 screws and a bunch of plugs and she is out. From there, remove the mounting brackets (2 screws each), 4 screws on the rear, 2 screws top and bottom and 3 screws holding in the small plates on each side. When you remove the back cover (tight fit), watch out for the power cable for the fan, I removed it so I could put the back aside. The mainboard is held in by 1 screw in the middle, 1 aerial at the top and 3 ribbon cables. If you've ever done any laptop stuff the ribbon cables are OK to work with, just pop up the retainer and they slide out. If you are not familiar just grab a 12 year old from an iphone factory, they will know how it works The case should now look like this:
    • Switching the console was tricky. First there were 6 screws to remove, and also the little adapter loom and its screws had to come out. Also don't forget to remove the 2 screws holding the central locking receiver. Then there are 4 clips on either side....these were very tight in this case and needed careful persuading with a long flat screw driver....some force required but not enough to break them...this was probably the fiddliest part of the whole job. In my case I needed both the wiring loom and the central locking receiver module to swap across to the new one. That was it for the console, so "assembly is the reverse of disassembly"
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
