Heya
I have been a motorsport enthusiast for quite a long time, however, one of the aspects that has recently taken my attention is karting, and is something i would really like to become involved with. I live in Adelaide, SA and i'm not quite sure if there are any clubs around adelaide, i haven't been able to find any on the yellowpages, any help with what i will need, (kart, helmet, etc?) where i will need to go to get them and where to go for training, lessons, clubs and that sort of thing would be very much appreciated.
Cheers.
Arky.
https://www.sau.com.au/forums/topic/105944-getting-started-with-karting-in-sa/
  • 3 weeks later...
hey mate i race karts in wa and have raced for about 3 years now its a great sport to get into but can get pretty costy i have raced in adelaide before there is a track there in bolivar i know pretty soon the nationals are gonna be there not sure if il be able to make it there though and yes you need a helmet, racesuit gloves and boots and u dont need a whole lot of training however alot of practise
Here's a list of clubs in SA - http://www.iwt.com.au/SAclubs.htm
Dont think its on the list but, theres also Angas Go Kart Club near Strathalbyn.
Recommend you look at Southern Sprint Kart Club's website, has all the basics you need to know to get started :). Hope you dont mind travelling long distances coz, theres plenty of it at club comp level.
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
    • I saw your intro update, are you sure you've actually had a starter motor failure? You mention it could be the alarm causing it. I'm assuming you've got a no start issue, but what are the exact symptoms, as there could be a few reasons it has stopped wanting to start.
