Pod Box....Really..WhY?
Sydneykid: when you say Lid, I assume you mean airbox lid?
Is your cold air box one of the UAS ones? or custom made?
So from your tests its really only worth doing a "partition" for the pod and not bothering with a full enclosure?
Is there a great noise difference between the lid being ON and OFF, cause I am hoping to quieten down my pod noise with the box too!!! [dont need cops following me around].
Thanks!
  • Replies 62
nismoR34, I have only a partiton, and the noise is greatly reduced, only makes noise when you put your foot in, not much at all when just accellerating to keep up with traffic etc. Even when accellerating hard, the noise is nowhere near as load - I can even hear the stock turbo spooling up now (though this may have to do with the heat shielding being removed as well?)
Not too sure about at the front of the car though, as there is a big hole for the CAI
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
