My anti lock dash light came on today, i found the fuse was blown and replaced it and now the left hand side indicators all stay on, I also checked the unit in the boot and the led flashed 8 times. What could be the problem I have disconnected the fuse because the indicator won't go off.
Any help would be great, Oh by the way the car is a R32 GTR.
https://www.sau.com.au/forums/topic/106442-anti-lock-dash-light/
ok I have used the trusty search button and one has seemed to have the same problem as me, now I have look through the manual and it has given me some idea of possibles on what it could be, However I still would like to know is why when I replace the fuse that the indicators on the left hand side (all of them) stay on??? Got me puzzled to why that would be... If any one knows someone or have had the same problem it would be very great full as the work shop manual dose not seem to have that in there....
I sorted out what was going on, The problem been was a faulty Actuator terminal, which is located right near the abs unit, there is a black box that sits right next to it which as the Actuator Relay and the terminal. :)
ok the problem has come back but the fuse did not blow this time, But the indicators on the left hand side are staying on same as last time, Iam going to change the Actuator Relay and see if that helps as soon as i find one, If this fails then i think i might have to go to nissan or some one who knows the problem,
I finaly found the sorce of the problem , after going over the car with a multi meter and checking the wiring looms i found that i had a short in my indicator wire on that left hand side.
The short was in the loom that runs under the raditor support.
replaced the wire and good as new. :P
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
