congrats on winning one of the classes, I was in the Datto, tried to cut a quick light but was a little too quick running a red :drag:
What mods have you done to yours? I saw it went 11.8, was that the best it had gone?
  • Replies 44
Posted Images
congrats on winning one of the classes, I was in the Datto, tried to cut a quick light but was a little too quick running a red :D
oh thanks!! i told your mate that we should of had another run
hks air filters
hks camgears
2510 turbos
apexi power/FC
blitz / apexi exhaust
os giken clutch
an the rest is stock
yea that is the first time i have run the car down the 1/4 i wanted to get 11.6, but it was way too hot that day
damn that was a preety big turbo on your car what type is it?
hks air filters
hks camgears
2510 turbos
apexi power/FC
os giken clutch
Yeah would have been a good race if we lined up again, I did a best of 11.6 in it that day. Thats a nice time you ran. Do you know what power the car makes? I was hoping for mine to go a bit quicker (I also had that gunmetal R32 GT-R) later on, but the RWD switch I had installed in the car played up and kept making the car go RWD on its own when I was running it after our final :P
The turbo on the Datto is a GT35/40 or GT35R (700hp roller bearing). Great for the street :rofl:
Edited by thebuzz
Heathcote might be a couple of 10ths of a second slower, but its a heap better place. Well run, nice people, realistic food prices, and Hot Jam Donuts, (yummy). Roll on Heathcote in November, coz I won't be running back to Calder in a hurry.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
