Would like to purchase these....
nah.. its ok...
just making sure that these forums dont go to waste...
Dark,,,if your not interested in purchasing,,,,DON'T POST in here,,,,You are starting to Annoy ME as well. Use the Wasteland please.
Neil.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
