I was thinking .... you measure your boost pressure at the inlet manifold, and it's say 12 psi with the stock cooler and stock turbo.
If the stock cooler has a pressure drop across it of around 6psi, this would be equivalent to your turbo pushing out around 18psi?
Then ... you upgrade your stock cooler to a nice FMIC with a pressure drop of say 2psi.
Could you then set your boost to run at 16psi (measured at the inlet manifold)??
The turbo would be running just as hard as before, but with a smaller pressure drop.
https://www.sau.com.au/forums/topic/10686-14psi-on-ceramic-turbs/
I see the logic...But..
When I installed my fromt mount IC there was no difference to the boost settings...
I also measure my boost from the manifold and I installed an APEXI Hybrid I/C... (definately felt the better flow of the cooler) but no boost decrease or increase...
Are you sure it's a 6 psi drop accross the standard I/C?
Regards
As for how long the turbo will last, remember that boost is not the only problem for the ceramic turbine. It does not like heat either, so when you turn the boost up it runs hotter (more air in means more exhaust out). Too hot and bye, bye turbine.
Hoep that helps clarify.
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
