Hey what is the average RB25DET getting for fuel economy?
I have a RB20DET and i am concidering the engin swap to the RB25.
I don't want to kill myself with fuel tho.. on average i will drive 1000km/week
in my RB20det it will cost me about $110-$130 Canadian per week. depending on my foot and how much i boost it!
I think that i am at about 13L/100kms or about 23MPG
Edited by James Mramor
https://www.sau.com.au/forums/topic/107142-fuel-economy/
After a tune I noticed no difference in fuel economy going from my rb20det to the rb30det.
Depending on how the car is driven I can get as low as 10.6L/100km's, ~470km's from full until the red light for local 50-60km/h driving. I don't drive in peak hour so no doubt fuel usage will rise if I were to.
Prior with dirty injectors, old o2 sensor and no tune (pfc base map) I was getting as low as 14L/100km's. At first with the dirty injectors I replaced the o2 sensor.. Did nothing, replaced injectors perfect. :D
Please do a search.. Remember to select to 'search any date' from drop down selection box.
https://www.sau.com.au/forums/topic/107142-fuel-economy/#findComment-1978336
Hi mate...
I've just rebuilt my RB25DET with some forgies, etc.. basically strengthened the motor for max boost... I high flowed the turbo but everything else (Ecu) is standard. Depending on how I drive.. I will get anywhere from 380 - 430 km out of a full tank.... It runs fine but I reckon if I got it tuned, I'd prob get about 450kms out of a full tank..
https://www.sau.com.au/forums/topic/107142-fuel-economy/#findComment-1978756
Hi mate...
I was getting the same as u with the new injectors, new o2 sensor but untuned pfc with the rb30det. :(
Displacement doesn't appear to make a big difference from 2-2.5-3ltrs..
https://www.sau.com.au/forums/topic/107142-fuel-economy/#findComment-1978798
new injectors eh?
i wonder if i could clean my old injectors . . . ...
im getting 300ks a tank out of my 200rwkw rb25det
driving style doesnt seem to affect it
i would like to get more
i think i should be
(should have mentioned, i just replaced my o2 sensor the other day, made no difference)
Edited by Spook's_Skyline
https://www.sau.com.au/forums/topic/107142-fuel-economy/#findComment-1994887
a little while ago i cleaned my AFM and fuel consumption is now great!
i can get 600+ km to a tank running 10 psi.
10L/100 kms is quite a good stretch of the fuel
before i cleaned the AFM i was struggling to get 500km / tank
https://www.sau.com.au/forums/topic/107142-fuel-economy/#findComment-1995071
air flow meter. Its on the air intake, tubular thing just connected to the airbox or pod filter depending on what u have. Will have wiring and a connector on it.
You can spray out the inside with circuit board cleaner or something, but be careful with it cause u can damage it and you'll then have to buy a new one.
https://www.sau.com.au/forums/topic/107142-fuel-economy/#findComment-1996022
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
    • Literally looks like direct port nitrous haha
