r33 skyline
400r body kit, tein coilovers, boost controller, remote start, turbo timer, rims, hks airpod, 3inch turbo back exhaust and more!!
16,500 click below for full ad. Deinately worth your time to look!!
http://www.carsales.com.au/pls/carsales/...rch_distance=25
also willing to trade for car of lesser value plus cash
Edited by charg1n
https://www.sau.com.au/forums/topic/107797-r33-skyline-for-sale-bargain/
I love this car so much, i love driving it when i get a chance, the reason i am selling my baby is because i need a deposit for a down payment on a house, i will miss her when she goes. For this price this car is a bargain, eveything works it has never had a major problem no leaks of any sort, Only just been serviced. Receipts for all modifications provided. All electrics fully functional. As soon as this car was bought an alpine Mp3, cd player was installed, along with a new heavy duty clutch also this car has been fitted with tein adjustable suspension, it also includes a full body kit which was on the car when i bought it . This car has recently been fitted with a 2 stage turbo smart boost controller, with boost gauge. It runs 8psi low boost and 12psi high boost (can be adjusted) the car was mostly run on low boost. The car has a sidemount intercooler, i have also installed a remote start kit, which includes turbo timer, this car can be started with remote over 1km away. The car also has been fitted with an alarm which has motion sensors, mircrowave sensors, shock sensors, door trip and bonnet trip which keeps the car very safe, absolute best you can get. This car is also fitted with a HKS air pod and has a 3inch turbo back exhuast system which sounds insane. The engine is in excellent condition with genuine kilometres unlike other cars on the market. Buyers more than welcome to have a compression test on the engine and they will discover it is healthier than many other engines reading 70,000 ks etc (117000 ks). No noises from the engine unlike other cars i've heard. Overall is a really nice car and a great weekend drive. Test drives welcome, and guys geniune buyers only.... all interest welcome just give me a call any time regarding any questions you might have.
Edited by charg1n
  • 2 months later...
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
